Individual Throttle Bodies
Old Jul 29, 2007 | 03:40 PM
brianironmanbaker's Avatar
Default Individual Throttle Bodies
Im looking to put ITBs on a H22...........only thing im wondering is what kind of sensors are used in place of a MAP/MAF sensor??? If you have any information that would help i would appreciate it
Old Jul 29, 2007 | 03:45 PM
hondamark35's Avatar
Default Re: Individual Throttle Bodies (brianironmanbaker)
not a topic i know much about... but i think you need a stand-alone fuel management system which would negate the use of some of the sensors.
wait for someone to back that up though. in fact there should be several threads out there about this... try a search if you haven't yet.
Old Jul 29, 2007 | 03:46 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Individual Throttle Bodies (hondamark35)
Ture. Most people use a standalone and eliminate the intake sensors.
ITBS can be done on a budget by hacking up an oem h22 manifold if you were curious.
Old Jul 29, 2007 | 04:30 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Individual Throttle Bodies (ek forever guy)
Does the same go for a B series mani too?
Old Jul 29, 2007 | 04:33 PM
Ek Forever y0!
Default Re: Individual Throttle Bodies (5_Lug_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B &raquo;</TD></TR><TR><TD CLASS="quote">Does the same go for a B series mani too?</TD></TR></TABLE>
As far as I know. Hold on.
Update: Damn, search engine is down. Someone made a diy of turning an oem b16 manifold into itbs.
Old Jul 30, 2007 | 10:06 AM
P12 EG6's Avatar
Dude.just but a hondata S300 and twm 52mm itbs . and itll run *******!!!!!! the s300 has air intake tables based on throtle position not MAP ,....
Old Jul 30, 2007 | 11:50 AM
doood's Avatar
been there done that
Default Re: (P12 EG6)
you can tune off the MAP, TPS, or a combination of both. you need a good vacuum log if you want to use MAP.
Old Jul 30, 2007 | 12:01 PM
preludedriva's Avatar
Default Re: (doood)
homemadeturbo has a write up on how to DIY ITBs
Old Jul 30, 2007 | 12:09 PM
darkclark's Avatar
Default Re: (preludedriva)
you mean this one http://homemadeturbo.com/tech_....html
i am almost done doing this for my friends b16 car we retain the map we made sort of a vaccume resevior to get readings off we are tuning with a chipped p28 ecu with crome
Old Jul 30, 2007 | 01:59 PM
96ej8MR's Avatar
and a stand alone fuel management system not a bad way to spend ten grand
Old Jul 30, 2007 | 02:00 PM
doood's Avatar
Default Re: (96ej8MR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ej8MR &raquo;</TD></TR><TR><TD CLASS="quote">and a stand alone fuel management system not a bad way to spend ten grand</TD></TR></TABLE>
what are you talking about?
Old Jul 30, 2007 | 02:05 PM
JKov240's Avatar
Default Re: (doood)
^Fast And The Furious quote...I feel so gay for knowing that
Old Jul 30, 2007 | 02:08 PM
Ek Forever y0!
Default Re: (doood)
I don't know. But this h22 in ITBS just made me
http://www.youtube.com/watch?v=yyeqxmlGG3M
Change Me
Honda Civic (2001 - 2005)
Apr 27, 2007 11:08 AM
sivikvtec
Dec 16, 2006 05:59 AM
civictildeath
10
Nov 22, 2004 09:57 PM
Toxic H
Mar 24, 2004 08:46 PM
DSRxCandyh2bEG
Mar 16, 2004 11:52 PM
