b20 vtec
Old Jul 29, 2007 | 12:30 PM
VtecHusker's Avatar
Default b20 vtec
I have heard that b20 vtec will wear down your bottom end faster than an ls/block is this true I would like to go b20 vtec turbo or should I just stick with b20 turbo. Any advise will help greatly.
Old Jul 29, 2007 | 12:38 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: b20 vtec (VtecHusker)
Most people swap the heads as to achieve better flow, and I guess for vtec too.
The bottom end isn't much for high revs, it was designed mostly for automatic cars, so getting an LS crank and some mild upgrades to the valve train would be a good idea.
It's a fantastic build motor, a lot can be done with them. But it's a trade off for all the parts you have to replace to make it reliable/semi-bulletproof.
Old Jul 29, 2007 | 12:41 PM
doood's Avatar
been there done that
Default Re: b20 vtec (ek forever guy)
ls and b20 cranks are identical
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecHusker &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that b20 vtec will wear down your bottom end faster than an ls/block</TD></TR></TABLE>
the people that tell you this are ricers. all they know are body kits and nos.
Old Jul 29, 2007 | 12:53 PM
Ek Forever y0!
Default Re: b20 vtec (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">ls and b20 cranks are identical </TD></TR></TABLE>
That's right, b20 is a stroked b18b.
Old Jul 29, 2007 | 01:30 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
bored
you're getting there
Old Jul 29, 2007 | 01:34 PM
Ek Forever y0!
I was unaware it was bored, I've always been under the impression just the stroke was changed.
Looking into it.
Old Jul 29, 2007 | 01:57 PM
doood's Avatar
b20b/z - 84mm bore 89mm stroke 140.69mm length rod
b18a/b - 81mm bore 89mm stroke 140.69mm length rod
Old Jul 29, 2007 | 02:02 PM
smileycvc's Avatar
Dood in for the save once again.
To the OP I would recomend just replacing the B20 rod bolts with ARP bolts and maybe a vtec oil pump, if you go with a vtec head. Once you go tubro you HAVE to tune or the motor wont even make it down the block. Detonation is killer of B20s.
Old Jul 29, 2007 | 02:15 PM
Ek Forever y0!
Default Re: b20 vtec (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">b20b/z - 84mm bore 89mm stroke 140.69mm length rod
b18a/b - 81mm bore 89mm stroke 140.69mm length rod</TD></TR></TABLE>
Shibby.
Old Jul 30, 2007 | 09:44 PM
.PLUMMM's Avatar
as far a reliability either can be good. friend of mine has a boosted b20 thats just nasty and another friend of mine had a built b20-t that was nasty as well. so as far as b20-t reliabilty im the 1st to vouch. havent seen much on b20/vtec just read alot and i see a lotta talk about the sleeves. so def look into that and just do some more research on HT on b20/vtec setups. Good luck!
Old Jul 30, 2007 | 11:47 PM
imcunner's Avatar
i was thinking bout gettin a b20 or a b18c
carlossolorzano
Nov 22, 2010 07:29 AM
VolkswagenWHO!!!
Feb 13, 2007 06:55 AM
hondachris1994
Mar 24, 2006 07:18 AM
cvclover
Dec 25, 2004 03:37 PM
