First timer!!!
Old Jul 28, 2007 | 11:11 PM
Midori Green's Avatar
Default First timer!!!
ok so i ran my car last night for the first time... damn felt good but cops came so i splittttttt.... but anyways i have a z6 with bolt ons but my question is what is a redline? and what is the redline on my motor?
Old Jul 28, 2007 | 11:23 PM
muhaMan's Avatar
im sure ur not gona be "splitting" anywhere with a z6 unless its turbo BUTT the redline on the d16z6 is 7200.. and the redline is the place that you DONT want to be unless you have a built head.. if you overrev you can blow your motor
Old Jul 28, 2007 | 11:50 PM
Syndacate's Avatar
Default Re: (muhaMan)
Redline = 7200
Car won't make power past 6800 - shift there - Well actually shift at 7100-7200 assuming you have a stock tach - because the honda OEM tachs read high as ****. If you have an aftermarket (good) tach - shift at where it says 6800.
Old Jul 29, 2007 | 06:03 PM
Default Re: (Syndacate)
yea i have to get a new tach cuz my current tach sometimes acts up but daily driving i dont beat my motor but when i run and yes i run a stock z6 against other stock d series engines if u dont know there is a class for everything but yea i shifted at about 7k
Old Jul 29, 2007 | 06:16 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Midori Green)
Where were you? A public street?
Old Jul 29, 2007 | 06:33 PM
Sr420Det's Avatar
Class. lol
Old Jul 29, 2007 | 08:19 PM
94c1v1cex's Avatar
Default Re: First timer!!! (Midori Green)
509 posts and you don't know what redline is? alrighty then...
my stock tach reads low as hell... i have an aftermarket tach that i don't keep in the car cause it looks ricey but i use it to adjust my idle and my stock tach is reading ~500 whereas the idle is 800
Old Jul 30, 2007 | 04:26 AM
Ek Forever y0!
Default Re: First timer!!! (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">509 posts and you don't know what redline is? alrighty then...</TD></TR></TABLE>
Being a base model owner it doesn't take long to figure out that redline = power stoppage.
Where your car doesn't make power anymore, ******* shift.
Old Jul 30, 2007 | 06:16 AM
jdmEF8racer's Avatar
Default Re: First timer!!! (ek forever guy)
................/ thread
Old Jul 30, 2007 | 06:48 AM
5_Lug_B's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
X2
Old Jul 30, 2007 | 07:04 AM
-Gary-'s Avatar
6800 is where you should shift, after that you're just spinning your engine and slowing down.
Old Jul 30, 2007 | 09:19 AM
s_vares's Avatar
all this info is correct but not.
Rev it out as high as you can before shifting.
though the engine makes no more power after a point.
when you shift your landpoint will be higher thus the next gear will be quicker.
come on now.
wind that motor out, is a dog, but it will do the trick.
Old Jul 30, 2007 | 05:42 PM
Default Re: (ek forever guy)
no at a spot but thats another story
SFlCrx
Sep 12, 2006 03:46 PM
Luchini
Mar 11, 2004 12:19 AM
SleepnCiViC
Dec 8, 2003 07:34 AM
00fbp
Feb 19, 2003 05:22 PM
bustaman0763
May 29, 2002 11:37 PM
