Check Engine Light
Old Jul 28, 2007 | 10:24 PM
924doorEG's Avatar
Default Check Engine Light
Today i was racing my JDM d15B non vtec 92 civic at the track and my thrid run down i was comeing around to get my time slip and my car threw a CEL light and started to like bogg down i guess? almost like im running on 3cylinders. well i let it cool off for about and hour before i drove home, it was fine all the way home not CEL light, then i pulled in my mobile home park with speed bumps and i live all the way in the back and i pulled into my driveway and the came on. and when its at idle without the clutch pushed in the idle drops like its going to die but it dosent. any ideas???? HELP!?
Old Jul 28, 2007 | 10:25 PM
stock99si's Avatar
Default Re: Check Engine Light (924doorEG)
make sure ur plug wires are plugged in
Old Jul 28, 2007 | 10:36 PM
924doorEG's Avatar
they are plugged in
Old Jul 28, 2007 | 11:00 PM
Syndacate's Avatar
Default Re: (924doorEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG &raquo;</TD></TR><TR><TD CLASS="quote">Today i was racing my JDM d15B non vtec 92 civic at the track and my thrid run down i was comeing around to get my time slip and my car threw a CEL light and started to like bogg down i guess? almost like im running on 3cylinders. well i let it cool off for about and hour before i drove home, it was fine all the way home not CEL light, then i pulled in my mobile home park with speed bumps and i live all the way in the back and i pulled into my driveway and the came on. and when its at idle without the clutch pushed in the idle drops like its going to die but it dosent. any ideas???? HELP!?</TD></TR></TABLE>
Did you check what code it's throwing?
https://honda-tech.com/zerothread/1901557
Even though it shut off, unless you reset the ECU (pulled battery terminal or cleared codes using an OBD scanner) they're in memory - do the method mentioned in that link and you can pull what they are.
Old Jul 29, 2007 | 12:36 PM
924doorEG's Avatar
okay i did the whole wire in plug thing and when i turned the power on it blinked 4 times kind fast, then it stopped for like 1 second and blinked 8 times, and ideas?
Old Jul 29, 2007 | 12:43 PM
pdiggitydogg's Avatar
uh......sounds like code 4 and code 8......
Old Jul 29, 2007 | 01:01 PM
924doorEG's Avatar
i have a video of it but i dont know how to upload it and i really need to know whats up with this, anyone got E-mail?
Old Jul 29, 2007 | 02:39 PM
924doorEG's Avatar
thats the link to the video can someone watch this and tell me what code that is plse
http://65.55.134.121/att/GetAt...dir=1
Old Jul 29, 2007 | 09:03 PM
924doorEG's Avatar
bump
Old Jul 30, 2007 | 01:03 PM
that link goes no where for me
grjp1988
Feb 18, 2008 12:13 AM
SiTR
Feb 14, 2008 04:19 PM
Ravell
Jan 10, 2008 05:47 AM
BseriesHeaven
May 22, 2007 08:01 PM
streetracerof06
Dec 2, 2005 08:28 AM
