Engine Light Question!
Old Jan 9, 2008 | 06:23 PM
Ravell's Avatar
Default Engine Light Question!
So at a traffic light less than 5 mins away from home my engine light came on at Idle... RPM less than 1000, Oil good, Gas good, Temps Normal...
So I decided to just park it and cab it home... Till I figure out what the deal is!
Symptoms: Engine Check Light > Rough Idle (At normal RPM), When pressing the accelerator lightly seem rough!
Note*** Timing Belt was done this past summer! 200o Teg LS
Any ideas anyone? Gimme some help before I call CAA to tow home 2 KMS
Rav
Old Jan 9, 2008 | 07:41 PM
PrinceAli132's Avatar
Default Re: Engine Light Question! (Ravell)
Check to see what code/CEL (Check Engine Light) your throwing.
How-to
Ali
Old Jan 9, 2008 | 07:42 PM
GRAF-FITI's Avatar
* B A N N E D *
are you serious? you parked your car and left it because the CEL came on? dude, you can drive it home...your engine isn't gonna blow up
Old Jan 9, 2008 | 08:06 PM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ravell &raquo;</TD></TR><TR><TD CLASS="quote">Rough Idle (At normal RPM), When pressing the accelerator lightly seem rough!</TD></TR></TABLE> maybe an o2 sensor? and dude, don't just park your car and leave it. do a search on stolen tegs once. plenty of them only left it there temporarily and came back to a stripped car, a missing car ect....
Old Jan 9, 2008 | 08:52 PM
LsVtecFoti's Avatar
I need some more info other than being at a redlight 5 min away from home.. did you run the car hard prior to??.. if its 5 speed did you miss any shifts badly? did you go through any large masses of water "big puddles" ? anything of that nature.. and if you did any of that.. could be an exhaust problem.. valve problems...caty. problem.. a ton of things.. my bet for you would be to go to a friend..or a guy your "in" with or anyone you know that has a OBD " On Board Diagnostic" system .. hook it up to your computer.. and it will let you know exactly whats wrong with the car Good luck bro
Old Jan 9, 2008 | 08:54 PM
LsVtecFoti's Avatar
and btw... if you like your car... NEVER leave it anywhere farther than 500ft from you. Treat it like you baby... because alot of people like our cars and they wanna take them from us! .....Horrible people.....
Old Jan 9, 2008 | 09:57 PM
Ravell's Avatar
Paper Clip test results in Code 73!
"73 random misfire cylinder 3"
Now What? Plugs and Wires?
Yah Manual Transmission, not driven hard prior! No puddles either...
Old Jan 10, 2008 | 05:47 AM
Default Re: (Ravell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ravell &raquo;</TD></TR><TR><TD CLASS="quote">Plugs and Wires
Ali
Sick CiviC EX
Honda Civic (2001 - 2005)
Oct 18, 2009 03:13 PM
lanojp1
Nov 25, 2004 08:53 PM
champwhiteitr
Mar 17, 2004 03:39 PM
HybridGSR1
Oct 6, 2003 07:32 PM
