car backfires bad?????
Old Jul 28, 2007 | 09:26 PM
beatthisspeed69's Avatar
Default car backfires bad?????
ok so i put a new head gasket on my sohc zc and at first i couldnt get the timing belt tight but then figured out it was the spring on the tensioner..so i finallye lined the cam gear to tdc and the lower pully also but wen i started it it has so much hesitation and then it backfires like it will take forever to get to like 4,000 rpm and then it starts to backfire like crazy so i was just wondering if anybody knew wat was wrong with it...backfire means non ignited gas right so isnt that off timing...but they are both on tdc...so ne bodys help will be appreciated
Old Jul 28, 2007 | 10:38 PM
Default Re: car backfires bad????? (beatthisspeed69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i put a new head gasket on my sohc zc and at first i couldnt get the timing belt tight but then figured out it was the spring on the tensioner..so i finallye lined the cam gear to tdc and the lower pully also but wen i started it it has so much hesitation and then it backfires like it will take forever to get to like 4,000 rpm and then it starts to backfire like crazy so i was just wondering if anybody knew wat was wrong with it...backfire means non ignited gas right so isnt that off timing...but they are both on tdc...so ne bodys help will be appreciated </TD></TR></TABLE>
n e body know wats up wit my car
Old Jul 28, 2007 | 11:56 PM
justseeingifitistaken's Avatar
take off your dizzy cap and see if teh screw for teh rotor has backed itself off...happened to me the EXACT same way before...sohc zc and everything...but i had my original stock dizzy
Old Jul 29, 2007 | 12:11 AM
by backed off you mean came off right in not wat do you mean by that
Old Jul 29, 2007 | 11:59 AM
Default Re: (beatthisspeed69)
the screw that holds the rotor in place backed out and was not holding it anymore. yopu get spark just not at the right time adn get backfires...its happened to a lot of us on here.
Old Jul 29, 2007 | 04:41 PM
well i took the cap off and it was still on there tight so i dont think that is it..so does n e body else have n e more ideas
Old Jul 29, 2007 | 05:08 PM
TomsEF's Avatar
Inactive account now known as MyspaceTom
Default Re: car backfires bad????? (hondaJDMimports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaJDMimports &raquo;</TD></TR><TR><TD CLASS="quote">take off your dizzy cap and see if teh screw for teh rotor has backed itself off...happened to me the EXACT same way before...sohc zc and everything...but i had my original stock dizzy</TD></TR></TABLE>
yea i had that prob when a local shop put on my new dizzy, i was lazy and i knew the guy, but my screw came out halfway through the Dragon so i was on the side of the road tryin to rig it together!
Old Jul 29, 2007 | 05:38 PM
man im stumped on this i checked the screw and it is on all the way
Old Jul 29, 2007 | 06:26 PM
janz3n's Avatar
buddy. check your timing again. id bet your 100 dollars its off.
Old Jul 29, 2007 | 06:59 PM
Default Re: (janz3n)
firing order!?!?!?!
Old Jul 29, 2007 | 07:59 PM
ive checked timing and fireing order over and over again..im stumped
Old Jul 30, 2007 | 02:43 AM
janz3n's Avatar
you checked them personally? if so get someone els to check.. if its still good.. theres something really wrong then.
beatthisspeed69
Jun 12, 2019 01:48 PM
O RLY
Mar 26, 2005 08:36 PM
CivicRaping
Mar 19, 2005 07:58 PM
boosted_zc
Mar 21, 2003 03:54 PM
Phatwhippin_CRX
Sep 9, 2002 02:46 PM
