Attn: Turbo owners need help!
I already did a search, and try posting this before but here i go again.
I have a 96 Teg automatic, My problem is im leaning out after 5lbs of boost. I have a vortech 10-1 FMU, AEM Fuel rail and an extra MSD Inline fuel pump. My wastegate is set at 10lbs and I can even past 5lbs ?!?! Im thinking my fuel injectors are at there full duty cycle and I need an upgrade ? or My automatic computer is not giving my car the gas i need and I should get a Fuel computer like a Apex'i S-AFC or a HKS AFR.
Any Ideas or suggestions will be appreciated. TIA.
MSD fuel pump won't work worth crap at the kind of pressures you're seeing with a 10:1 FMU. You have a few options:
Bosch inline fuel pump (see http://www.theoldone.com)
Larger injectors (310cc injectors w/ 8:1 FMU, etc.)
Ditch the FMU completely and go with 450cc injectors (do a search for "dsm injectors") and a SAFC.
gtowni3
Mar 17, 2004 07:59 PM
