FS:B20z Vtec Motor Freshly Built with gs trans $1000
Old Jul 28, 2007 | 05:11 PM
jdmbeegee's Avatar
Default FS:B20z Vtec Motor Freshly Built with gs trans $1000
Needs Head Work there is ticking in the head but runs fine
Motor has 272 Miles on it with new rings and JE 12:5.1 Compression Pistons LS Rods with ARP Rod Bolts LS Micropoished and Balanced Crank B16 Head ARP Head Studs GSR Cams
New Timing Belt Water Pump Oil Pump Head Gasket Set
I have the reciept for this build it was around 1500 for assembly with new bearings gaskets etc.
Im asking 1000 for just the long block and trans
Modified by jdmbeegee at 9:23 AM 10/9/2007
Old Jan 21, 2008 | 10:05 PM
Jintegragsr97's Avatar
Default Re: FS:B20z Vtec Motor Freshly Built with gs trans $1000 (jdmbeegee)
GS trans as in LS or you mean gsr?
stinner.5
Sep 26, 2012 08:22 AM
brandnewman16
Sep 25, 2007 07:30 AM
hotimportcrx
Northeast (Sales)
Mar 27, 2006 06:51 PM
untitled
Jan 15, 2004 01:57 AM
untitled
Sep 11, 2003 12:58 PM
