lighter aem pullies
Old Jul 28, 2007 | 01:10 PM
stock99si's Avatar
Default lighter aem pullies
Hey im just wondering are Aem pullies worth it for a b16a?
ive never really upgraded pullies on any of my cars, and im just wondering does it give me any gain?
and i also heard that it messes up your timing.
someone clearify please
Old Jul 28, 2007 | 01:13 PM
hondamark35's Avatar
Default Re: lighter aem pullies (stock99si)
unless it's the timing belt pully... it won't effect the timing.
Old Jul 28, 2007 | 01:17 PM
stock99si's Avatar
Default Re: lighter aem pullies (hondamark35)
can i expect any gains at all with this?
Old Jul 28, 2007 | 01:19 PM
GarageAlchemist
Guest
Posts: n/a
naa dood, you got a 16 second car.. work on things that are effective, displacement, cams, air flow, etc.. screw all the silly crap
Old Jul 28, 2007 | 01:20 PM
h22a1_julien's Avatar
Default Re: lighter aem pullies (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">naa dood, you got a 16 second car.. work on things that are effective, displacement, cams, air flow, etc.. screw all the silly crap</TD></TR></TABLE>
X2
Old Jul 28, 2007 | 01:33 PM
my thought is that under-drive pullies are only good for a track car that will spend a lot of time in high rpm. this is because you aren't spinning your accesories fast enough when you are driving under normal conditions.
you can get similar effects by removing your a/c compressor and PS pump(and it's cheaper that way) if you are really concerned about being fast, you can stand to get rid of these...
the only other thing is if you have a "balanced" pulley like accords and preludes. (can't remember if some b16's have them or not) if this is the case, a stock size but light weight pulley will have results similar (but lesser) to a lightened flywheel.
all in all not worth it unless you are trying to shave hundreths off 1/4 mile times of an already highly tuned and modified car.
Old Jul 28, 2007 | 01:38 PM
stock99si's Avatar
...16 second car? maybe thats what ur d is pulling, certainly not any of my cars.
anyway.
okay guys thanks for the input.
Old Jul 28, 2007 | 01:51 PM
GarageAlchemist
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">...16 second car? maybe thats what ur d is pulling, certainly not any of my cars.
anyway.
sorry if it doesn't run a 16, most of the time whenever i see someone with pullys they run a 15 or slower.. then complain about there vafc tune not being right ( lollers )
but i guess you have some engine work done then ?...
Old Jul 28, 2007 | 01:55 PM
stock99si's Avatar
a stock si with a b16 runs under 16.
a crx with a b16 wont run over 15...even with a retard as a driver.
Old Jul 28, 2007 | 02:01 PM
GarageAlchemist
Guest
Posts: n/a
shrug, 15, 16 seconds, all the same.. when your car is the same speed as a hyund/kia i wouldn't think too much of the numbers..
Old Jul 28, 2007 | 02:08 PM
stock99si's Avatar
what makes u so confident bro?
a stock rsx type s runs low 15...what do u expect?
if you believe that theres no dif between 15 seconds and 14, and that if you believe if ur stock car is as fast as a hyundai...you should seriosuly step out of the honda scene and get into some big chevy v8's
Old Jul 28, 2007 | 02:29 PM
Padawan's Avatar
Darth ModerVader
Let's keep the discussion on-topic and dispense with the bickering, or points will be docked.
richeybrooks
Apr 11, 2006 10:12 PM
alpha
Oct 28, 2005 04:43 PM
90crxsib16
Jan 12, 2005 03:45 PM
ranta18
Sep 21, 2004 09:39 AM
DOHCon15s
Sep 10, 2003 06:48 AM
