Trying to figure out what these front spindles are from *pics*
Old Jul 28, 2007 | 10:23 AM
drewboy's Avatar
Default Trying to figure out what these front spindles are from *pics*
I have no clue what these front hubs are from, is there any visual clues on the rotors/calipers that will tell me what Honda they are from? I think they are either from an EG or a DC. Can anyone visually tell?
Modified by drewboy at 11:48 AM 7/28/2007
Old Jul 28, 2007 | 10:32 AM
BlueIntegraBoy's Avatar
Default Re: Trying to figure out what these front spindles are from *pics* (drewboy)
Measure the rotors. 10.25" diameter rotors are more likely to be Integra (9.5" Civic/10.25" Civic EX). Only way to tell the difference between Integra and Civic EX brakes are the calipers or check for the ABS wiring mounts. Check for screw holes on the knuckle, indicating they had ABS, which means it is from an Integra or Civic EX ABS (same brakes as Integra). If the rotors are 10.25" wide, but have no ABS wiring mounts on the knuckle, then they are from a Civic EX non-ABS. If you see two holes near the top of the knuckle where the balljoint connects to, then they are from a 90-93 Integra. Hope this helps.
Old Jul 28, 2007 | 10:49 AM
drewboy's Avatar
dang man, i appreciate the help, ill go check that out
Old Jul 28, 2007 | 10:57 AM
si_motor_spt's Avatar
Default Re: (drewboy)
Id say, they look like 96-00 civic ex brakes.( they look like mine thats why) mines is a non abs and that looks pretty similar....
Old Jul 28, 2007 | 11:06 AM
Those are Integra brakes, most likely. The lines running down the side are the ABS sensor wires.
Old Jul 28, 2007 | 11:12 AM
eg6sir-s's Avatar
92-95 civic ex/si-abs models
94-01 integra ls, gs, gsr abs models
mr abstract
Dec 27, 2006 10:48 AM
Smashback
10
Mar 22, 2005 12:33 PM
servion
Jan 3, 2003 12:14 PM
youngkow
Nov 14, 2002 06:16 PM
