i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice?
Old Jul 28, 2007 | 08:47 AM
DJNauTicz's Avatar
Default i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice?
i have a Ls in my hatch..but i'm thinkin..should i go for Ls-V or Turbo?
if i go for turbo..wat part's i should get is better for it??
Old Jul 28, 2007 | 10:18 AM
Dilly's Avatar
Default Re: i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice? (DJNauTicz)
i'd go for a turbo. because LS-Vtec wont last long if made poorly. unless its built nicely, then it wouldn't be a problem.
check out the forced induction forum on here to build up some knowledge on turbo's.
GL.
Old Jul 28, 2007 | 11:11 AM
BlackoutVTi's Avatar
Default Re: i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice? (diLLy :])
LS/VTEC is a little dicey and precarious. If you do decide to go that way, there will be no rewards for cutting corners. I would say, keep the reliability of the stock LS engine, get some shorter gears, and begin preparations for forced induction.
Not sure what you're asking about what parts would be better for the engine? Do you mean brandnames, or?
Old Jul 28, 2007 | 11:13 AM
posHonda's Avatar
turbo ftw!
Old Jul 28, 2007 | 11:54 AM
DJNauTicz's Avatar
Default Re: i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice? (BlackoutVTi)
yea..like wat brand is better..and wat kind..
Ls-V cosh cheap...and LS turbo is nice....still thinking...
need more advice..and DIY???
Old Jul 28, 2007 | 11:58 AM
pdiggitydogg's Avatar
You seriously cant make up your own mind from searching for previous threads on either/same topic?
You really need others to tell you what to do period?
Old Jul 28, 2007 | 12:00 PM
Dilly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz &raquo;</TD></TR><TR><TD CLASS="quote">yea..like wat brand is better..and wat kind..
need more advice..and DIY???</TD></TR></TABLE>
well, there are a lot of good brand out there for turbo's. you just gotta do your part of searching.
have you checked out the forced induction forum yet? i suggest you do that if you havent...
Old Jul 28, 2007 | 12:08 PM
hard charging 929's Avatar
what do you want to do with the car? "I wanna go fast"
How fast do you want to go?
There's a LS-T thread like 397987249273912347 pages long with tons of setups and great info. on doing LS-T.
If it's allmotor you looking for there are many threads you can find via the search function to get your info. from. If done right you can get good power and reliabitly from an ls/vtec.
Or you can stay all motor LS and still make good power. The road less traveled.
Old Jul 28, 2007 | 03:03 PM
DJNauTicz's Avatar
Default Re: i got a Ls Swap in my Hatch.but Thinkin i should go Ls-V or Turbo. advice? (agoldenau)
im sure alots of people out there can't decide there mind.that's why they want to find out wat other people think.....
agoldenau
i want to pull like 200 on my ride..or little bit more..but i'm not tryin to spend tone's of money on it..that's why....so i just want a decent power..that's all.
Old Jul 28, 2007 | 03:05 PM
posHonda's Avatar
with the money spent to have a reliable ls/vtec, you could have spent that on a turbo setup.
Old Jul 28, 2007 | 03:39 PM
Deep V's Avatar
bump for the boost!
JLopezDC2
Jul 31, 2012 10:06 PM
honda_ek9
Jul 9, 2008 07:21 PM
JnyStylz
64
Dec 29, 2004 07:24 PM
ANBUone
Nov 20, 2004 10:42 PM
Integra717
May 19, 2002 11:22 AM
