Anyone running a Dynomax WLK-17749?O
Okay so I ordered this muffler from Summit after taking a look at the specs and taking a few measurements.
I got it today.
It's much much bigger than I anticipated...the body itself is 20" long and the inlet/outlet are both 2.5".
Looking under my car, it's going to be a pretty tight fit. I'm not sure it'll work, plus the rest of my piping is like 2", so I'm going to need to run bigger piping or a reducer somewhere, which will make it even longer (if I put it crosswise, the other option would be to put it further upstream, which would make things easier but be more $$ since I'd be replacing more piping. The current piping is less than a year old).
So, does anyone have this muffler or something similar in dimension stuffed under their car?
Should I return it? It might not even be worth it after I pay for the shipping both ways plus duty since I'm in Canada, etc, etc.
Or any suggestions for a decent muffler in the $50 range?
I got it today.
it's to late now but you should have ordered the summit turbo muffler,same **** but $17.99...summit brands are always made by some other company,like their cams for example are mostly made by crane..
I personally would just use the muffler since you have it and put it in the stock position..
also look here https://honda-tech.com/zero...age=1
if the Greddy SP and APEXi World Sport can fit ... that should
if you want to do your whole exhaust over again... might I recommend
http://www.vrsexhaust.com
as well as 2 x 2.5" moroso spiral flow resonators
dont bother with KTeller... he is just making money reselling VRS and charging jacked up shipping on stupid **** like $30 for a flange.
