my high beam lights is going crazy on me
i cant seem to turn my high beam off..i push the bar in to turn it off but the high beam clicks on and stays on..does anyone have the same problem or had it?..i didnt touch anything to the car and it just happened..any help?
Sounds like it's the headlight combo switch.
When that thing goes out it ***** with your high beam/low beam so badly.
For me the problem was the low beams stopped working, but the high beams worked, but either way, if it was set to low or high, the high beam light indicator on the dash was on.
The problems vary from there, but it definitely sounds like the headlight combo switch.
EDIT:
http://slhondaparts.com/browse...3-A02
Or you can just get one from a junkyard, real easy to replace.
EDIT:
Speedy5966
Jun 8, 2019 10:51 AM
Audemon
Mar 6, 2016 03:15 PM
