Replacement exhaust rattling against stock shifter...(not short shifter)
Old Jul 27, 2007 | 04:29 PM
KHowe's Avatar
Default Replacement exhaust rattling against stock shifter...(not short shifter)
Hey all,
I'm having a problem. I recently purchased an "oem" exhaust to replace my World Sport. The problem is the resonator is rubbing up against the shifter. It's rubbing against what appears to be a weighted piece at the end of the shifter, which I assume is to help carry momentum in the shifter and help it get into gear, though I'm unsure. It makes a loud metal on metal rattle, and shakes the shifter inside the car. I took a picture to help illustrate what I'm talking about.
The only methods I can come up with to fix this problem are a) buy a longer rubber exhaust hanger, b) hammer the top of the resonator to flatten it, c) use a sawzall on that weighted piece.
The longer rubber exhaust hanger bit seems the simplest solution, though no local automotive stores carry this part. Does anyone know where I can order one? When I take the hanger off, the exhaust seems to hang low enough to clear the shifter, though I don't feel comfortable driving it around this way (though I'm sure it's probably fine). If anyone could help it would be greatly appreciated. Thanks
Old Jul 27, 2007 | 04:34 PM
HiProfile's Avatar
Default Re: Replacement exhaust rattling against stock shifter...(not short shifter) (KHowe)
You could also try bending the steel hanger. Heat it up for a while with a torch, then use a pipe to get leverage on it (and not get burned). I would also pound the resonator in for good measure.
Old Jul 27, 2007 | 04:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Replacement exhaust rattling against stock shifter...(not short shifter) (HiProfile)
Rust =
I fixed a similar problem on a friends car. I just took a prybar and bent the exhaust piping out of the way just enough that it would not hit the shifter.
Old Jul 27, 2007 | 04:56 PM
KHowe's Avatar
Thanks for quick replies.
HiProfile, I also thought of doing that; however, my first choice is still to get a longer exhaust hanger as it seems to be the 'cleanest' method. If I can't find one within a day, I'll take that approach. Thanks.
Old Jul 27, 2007 | 05:20 PM
ke98248's Avatar
Default Re: Replacement exhaust rattling against stock shifter...(not short shifter) (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Rust =
I fixed a similar problem on a friends car. I just took a prybar and bent the exhaust piping out of the way just enough that it would not hit the shifter.</TD></TR></TABLE> Easiest solution, lol
Old Jul 28, 2007 | 05:55 AM
KHowe's Avatar
Bump, anyone else?
Old Jul 28, 2007 | 07:30 AM
instrument's Avatar
it looks like you're already rubbing with the resonator at the height its at now.
i'd bend the hanger, i'm unsure of why you're worried about it being a clean fix, its a hanger for a muffler under your car, just take some pliers to it and be done.
Old Jul 29, 2007 | 02:38 PM
KHowe's Avatar
I tried the pliers and couldn't get it to bend. I'll probably have to take the exhaust off to be able to bend the hanger.
I found these, I'm not sure how much longer they are than OEM since they don't give you a dimension...
http://www.allwheelengineering...B-011
Old Jul 31, 2007 | 07:13 AM
hust1er's Avatar
Default Re: (KHowe)
I just got the XL hangers from them for my 00 si. They are bout a inch to an inch and a half longer then stock.
But the wholes in the hangers are bigger then the stock hanger hole...so its real loose.
Thats the only reason why i havnt put mine in...i kno chances of the exhaust hangers jumping up and sliding off with my exhaust are low but im not riskin it
elmalouno
21
Sep 12, 2011 04:52 PM
Frost7177
Jan 17, 2007 09:29 AM
SLOAZZ95
Oct 20, 2003 01:39 PM
CDN Yellow ITR
Jul 7, 2003 08:50 AM
crxzc
Jul 2, 2002 05:09 AM
