possible blown head gasket? these are my symptoms....
Old Jul 27, 2007 | 01:23 PM
taimysho0's Avatar
Default possible blown head gasket? these are my symptoms....
OH HELLO!! i have a 2000 honda civic si. i just bought it and now i noticed that when i floor it, theres a weird burning smell. the guy i bought it from said that the car was sitting in a garage for 2 years before he sold it to me. i checked my oil, but its not going low, its normal. there is white smoke coming out of my exhaust. i looked inside the coolant reservoir and it looked good except i could notice some reflection (the kind that oil gives off rainbowish kinda thing). also i opened the radiator cap and saw about 3 tiny black dots that could possibly be oil. iono if my exhaust is old or if i have a severe problem with the head gasket. i took out the spark plugs and noticed that the first 3 plugs have oil at the tip but did not have a socket to pull out the spark plug itself. the car does not leak any oil or coolant. could i have a blown head gasket? blown rings maybe? or do i just need to replace the spark plug seals? if so, what could be that bruning smell??? THANK YOU
Old Jul 27, 2007 | 01:43 PM
slowcivic2k's Avatar
Default Re: possible blown head gasket? these are my symptoms.... (taimysho0)
Coolant coming out the exhaust will have a sweet smell, if it runs pretty well, I would not suggest a problem with the head gasket, a tune up after sitting that long and a change of fluids should be done as soon as you can.
Old Jul 27, 2007 | 02:15 PM
blk92_d16's Avatar
Yeah, first thing I'd do is drain any gas that was remaining in the tank. Then I'd do a full fluid flush and tune-up. New spark plugs, new fuel filter, new air filter, oil/filter change, tranny flush, coolant flush, etc etc.
Good luck!
Old Jul 27, 2007 | 05:02 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, first thing I'd do is drain any gas that was remaining in the tank. Then I'd do a full fluid flush and tune-up. New spark plugs, new fuel filter, new air filter, oil/filter change, tranny flush, coolant flush, etc etc.
Good luck!</TD></TR></TABLE>
X2
Do that and then let us know if you still have those symptonms. 2 years is a pretty long time.
Old Jul 27, 2007 | 05:11 PM
taimysho0's Avatar
so you guys are sure theyre is nothing wwrong with the head gasket??? even with all these tell tale signs?? thanks
Old Jul 27, 2007 | 05:13 PM
taimysho0's Avatar
i used up old gas, put in new 91, flushed out old oil, put in new synthetic oil, and new filter. there is no sweet smell from the exhaust but alot of smoke comes out when i rev it at high rpms. thanks
Old Jul 27, 2007 | 05:20 PM
taimysho0's Avatar
also, the day after i bought the car, i smogged it and it passed. however i later checked the dipstick and there was barely any oil in it and i accidently put in 6.5 quarts of oil in it. i drove it about 25 miles like that without knowing and gunned it a couple times but only up to like 3rd gear and the next day i had it drained, could the gasket be blown because of that?? the engine has about 60k oem motor
Modified by taimysho0 at 6:34 PM 7/27/2007
Old Jul 27, 2007 | 09:40 PM
Default Re: (taimysho0)
No, the worst thing that could happen is the engine would feel like it is missing power due to oil hitting the rotating parts, but even that is a long shot.
Overfilling would cause the oil pan gasket to seep, and if it does it shouldn't require replacement, simply spray any seeping oil off and your good.
Shaaks69
10
Jul 21, 2014 02:52 AM
a3k
Jul 26, 2009 10:36 PM
projcinco
Aug 28, 2008 06:10 PM
CBlockDis
Jul 16, 2005 11:55 AM
