Pulled the head and this is what I see *pics*
Old Jul 27, 2007 | 12:54 PM
low91rex's Avatar
Default Pulled the head and this is what I see *pics*
Well this is the story I was accelerating at the top of 2nd gear when I hear a horrible grinding sound and loss of power. The sound was really loud and sounded like stuff was shattering I pulled over immediately and the sound continued for a few seconds then it just died. So I try to start it again like a dumbass and the sound was there but it wouldnt start. I pop the hood and wow My timing belt is SOOO LOOSE and half way off. So I said crap I must have bent my valves. so this morning I pulled the head and there appears to be no damage??? WTF??? so what was that sound ?
The valves seem to be ok, tell me what you think.
Also Since I suck at having a honda what should I do, This is a DPFI dx motor, I was thinking of sending out the head getting it milled (im pretty sure its warped cause my oil looked like milk when i pulled the valve cover) throwing a cam in and switching over to mpfi get a header, and later on boost it. or some sort of swap. In a sense I would like to know what would be more cheap and most powerful.
Salvage this DX 1.5 or get some type of swap.
Old Jul 27, 2007 | 12:58 PM
bigluelok's Avatar
Default Re: Pulled the head and this is what I see *pics* (low91rex)
check your cylander walls make sure they arent cracked
Old Jul 27, 2007 | 01:25 PM
low91rex's Avatar
Default Re: Pulled the head and this is what I see *pics* (bigluelok)
I just did they seem to be ok I dont understand what could of mad that sound.
Oh and in case you were wondering why the tbelt just came loose was because the I didn't tighten the tensioner so it probably jumped a zillion teeth.
Old Jul 27, 2007 | 01:50 PM
bigluelok's Avatar
check out your oil pump.... was it a clacking sound?
Old Jul 27, 2007 | 01:53 PM
low91rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigluelok &raquo;</TD></TR><TR><TD CLASS="quote">check out your oil pump.... was it a clacking sound?
Yeah and now that I think about it when it happened there was oil all over the belt. And It drips oil from the crank area.
Old Jul 27, 2007 | 01:56 PM
mahatma's Avatar
maybe it was just the belt flopping around in there? slapping the timing covers.
p.s. if you want power, start by tossing that head (& block if it were me) in the nearest dumpster....regardless of it's condition.
Old Jul 27, 2007 | 02:05 PM
low91rex's Avatar
Default Re: Pulled the head and this is what I see *pics* (mahatma)
Nah it sounded like metal on metal.
And about the power, my original plan was to find an b18 ls, but im broke I cant afford mounts, linkage, engine itself. And wiring isn't my favorite thing to do.
So me with my broke situation I was thinking a d16 from an si then boost that later. Or salvage this d15 switch to mpfi throw a cam in, clean and mill the head. and boost that later on.
Old Jul 27, 2007 | 03:29 PM
thehatchninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low91rex &raquo;</TD></TR><TR><TD CLASS="quote">
Also Since I suck at having a honda what should I do, This is a DPFI dx motor</TD></TR></TABLE>
Throw it away!...just kidding. Actually, if you're wanting to boost it I'd start with a healthier motor. I'd try to pick up an A6 or a Z6.
Old Jul 27, 2007 | 05:24 PM
low91rex's Avatar
Default Re: Pulled the head and this is what I see *pics* (thehatchninja)
Your right Im gonna start searching for a new motor. But I don't just want to give up. Im trying to learn some stuff, so I might give this one a rebuild too.
Old Jul 27, 2007 | 08:17 PM
1989CivicSi's Avatar
Pretty much the same thing happened to me on my SOHC ZC...heard a whirring noise for the longest time like a bearing was going out, eventually started losing power driving home from SoCal to NorCal...pulled off at the exit to my house and killed the car half a block from my house. Defective OEM water pump was grinding metal on metal because the bearing went out.
I lucked out that the car made the 5 hour drive back home only to die on the street to my house .
Old Jul 27, 2007 | 09:33 PM
low91rex's Avatar
Default Re: Pulled the head and this is what I see *pics* (1989CivicSi)
haha I know what you mean, Thats how it sounded when I got the car, I changed the water pump and it went away. But because i didn't tighten the tensioner the belt jumped off and this happened.
The sound I heard was more like a loud crackling noise.
Old Jul 27, 2007 | 09:51 PM
nihad's Avatar
yeh the a6 is great just got mine running tonight wow hhow nice man.
Old Jul 28, 2007 | 12:12 PM
Default Re: Pulled the head and this is what I see *pics* (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">yeh the a6 is great just got mine running tonight wow hhow nice man.
an a6 in a crx is fun, even if it's a stock Si. Do yourself a favor and get the A6 trans too.
civic_99ex
Mar 10, 2010 07:50 PM
bara6075
Oct 6, 2007 02:58 PM
teh hatton
Jul 17, 2007 09:45 AM
vietboiracer0
Nov 24, 2005 08:11 PM
japspecjohn
21
Dec 17, 2003 03:17 AM
