Full F & R NSX caliper conversion. Anyone have this setup on EG or DC?
Hi, I just purchased a full set of 99 NSX calipers for my EG. I already know exactly what I need to get the fronts working properly, but I have some concerns regarding the rears. I cantacted fast brakes, and they do have the caliper brakets for 92-03 NSX calipers to bolt up to the EG rear. I've searched, but does anyone actaully have a full set currently on there car? I heard of some people saying that the rear NSX calipers tend to lock up, becasue they were designed for a mid-engine car, and EG's have almost no weight in the back. Just want some input before I spend another 300 on rear brackets and rotors... Thanks.
Pm brakeexpert.
he made a conversion chart, I suggest you browse through some of his created threads, I'm sure he's posted details on his own nsx brake swap. He usually does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Pm brakeexpert.
I've read that link, but my main concern is the rears locking up if I decided to install the rear NSX calipers. I would like to get some real world experiance from someone who has this setup. It would look so sweet to have F & R NSX calipers, but I don't want a setup that looks good but has locking issues.
Hey guys. Ok I have NSX front calipers on my EK, 11.1" front rotors. My backs are 10.2" ITRs. This has essentially the bias of an ITR, give or take a little, and it will lock all 4 wheels evenly almost all the time, so you're using its limit. The NSX rear caliper uses a much bigger pad and also a taller pad, giving a larger sweep on the rotor. Given the increase, if you wanted a near stock bias, I would reccomend pairing this with bigger than an 11.8" front setup (there exists an 11.8" NSX setup using pretty good sized pads). I would actually reccomend bigger than that to pair with the NSX rear setup. Unfortunatly given the brackets, the biggest tested setup I've found is the 11.8" rotor, any bigger I haven't tested or built. I have a 12.3" and 12.6" Acura RL (4 piston) setup coming, tho you will have Acura on the front and NSX on the back.
I don't know if the NSX bracket has to be tapped, my only confirmation is that the NSX rear caliper CAN go on the back. A guy with a RWD integra had these on and he mentioned using the 10.3" FRONT vented discs from a civic EX/Integra. I sold my rear NSX calipers quickly a few months ago without getting to test them and believe me I regret it. This RWD Integra is the only car I know to use both the front and rear NSX calipers on his car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">Hey guys. Ok I have NSX front calipers on my EK, 11.1" front rotors. My backs are 10.2" ITRs. This has essentially the bias of an ITR, give or take a little, and it will lock all 4 wheels evenly almost all the time, so you're using its limit. The NSX rear caliper uses a much bigger pad and also a taller pad, giving a larger sweep on the rotor. Given the increase, if you wanted a near stock bias, I would reccomend pairing this with bigger than an 11.8" front setup (there exists an 11.8" NSX setup using pretty good sized pads). I would actually reccomend bigger than that to pair with the NSX rear setup. Unfortunatly given the brackets, the biggest tested setup I've found is the 11.8" rotor, any bigger I haven't tested or built. I have a 12.3" and 12.6" Acura RL (4 piston) setup coming, tho you will have Acura on the front and NSX on the back.
I don't know if the NSX bracket has to be tapped, my only confirmation is that the NSX rear caliper CAN go on the back. A guy with a RWD integra had these on and he mentioned using the 10.3" FRONT vented discs from a civic EX/Integra. I sold my rear NSX calipers quickly a few months ago without getting to test them and believe me I regret it. This RWD Integra is the only car I know to use both the front and rear NSX calipers on his car. </TD></TR></TABLE>
Thanks for the input. There's not much discussion about rear NSX calipers on HT... Based on the info I've found so far, it's probably best if I just do the NSX calipers in the front. Thanks again.
scarsofterror
Jul 21, 2011 04:02 PM
eg underclassman
Oct 22, 2006 10:08 PM
