failed emissions
Old Jul 27, 2007 | 10:31 AM
blinger's Avatar
Default failed emissions
help me figure out what needs to be done to the car for it to pass
hc low 2461
hc high 3055
co low 1.51
co high 7.64
co_co2 7.45 low and 14.76 high
EDIT: sorry, it is a completely stock 93 civic 1.5 - brand new stock cat back exhaust.
I'm a potential buyer of the car. The seller took it to get it inspected and it failed emmissions, these are the scores. I was just wanting some insight on them on what I would need to do to get it to pass
Modified by blinger at 11:47 AM 7/27/2007
Old Jul 27, 2007 | 10:33 AM
BlackoutVTi's Avatar
Default Re: failed emissions (blinger)
Engine? Car? Smog equipment? Mods?
andoxviii's Avatar
You might want to give some more information.
What car are you driving?
What engine is in the car?
What modifications have you done to the car?
Old Jul 27, 2007 | 10:38 AM
THC07's Avatar
Default Re: failed emissions (andoxviii)
and then tell us why you failed?
blinger's Avatar
Old Jul 27, 2007 | 10:40 AM
Hm, check engine lights? Is your evap connected? O2 sensor functioning?
(off the record) Blown headgasket?
Old Jul 27, 2007 | 10:48 AM
blinger's Avatar
Default Re: failed emissions (BlackoutVTi)
what are the legal limits compared to the numbers i posted?\
Old Jul 27, 2007 | 10:59 AM
Should be explained in the paperwork. The legal limits should be displayed along side your readings to show the comparison from your run on the dyno.
Old Jul 27, 2007 | 11:04 AM
HarfordCTR's Avatar
lower your car. Works here in MD. I pull up, they say my cars too low, the write me a waiver thats good for two years. U don't even have to pay the fifteen dolars. I don't even get in the line anymore. I go right inside and tell them its too low. They write it off for another two years. My car isn't even that low. haha
Old Jul 27, 2007 | 11:17 AM
Default Re: failed emissions (HarfordCTR)
Lol, wtF! I went into my ref appointment, and they said I was too low too. The only problem was they said "You have 3 mins to adjust your ride height, or you'll have to reschedule in like a month."
You must have a real laid back system there.
Old Jul 27, 2007 | 11:37 AM
blinger's Avatar
you live in California, he lives in Maryland.
2 completely different states as far as car laws
but im gonna try changing the cat - will a high flow pass?
Old Jul 27, 2007 | 11:38 AM
DxBurnoutKing's Avatar
Bad Cat, Faulty O2 sensors.
since you say that you have a brand new exhaust.. those are the only reasons I can think of as to why you'd fail an emissions test.
Old Jul 27, 2007 | 11:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">will a high flow cat pass?</TD></TR></TABLE>
A high flow cat passed for me, and, as you've noticed, I live in the great state of California, where you're not allowed to fart without getting a ticket for being a gross polluter.
Old Jul 27, 2007 | 11:48 AM
HarfordCTR's Avatar
they really said you have 3 min to adjust your ride height? I've gotten away with the lowered car deal 3 times already. Guess MD laws arent that bad after all
Old Jul 27, 2007 | 01:14 PM
Relic1's Avatar
either the wrong ECU (or chipped with funky maps) or the O2 is about ready to die. I'd be leaning towards the latter of the two.
the lowered trick worked here in IL also, but they required an idle test.
Old Jul 27, 2007 | 02:08 PM
hard charging 929's Avatar
Default Re: (Relic1)
have you pulled the plugs to see what they look like? What's the year on the wires? How's the cap and rotor look?
Might just need a tune up.
How's the air filter?
Old Jul 27, 2007 | 03:28 PM
ddd4114's Avatar
Default Re: (agoldenau)
- bad o2 sensor
- clogged/broken cat
- plugs/wires/cap/rotor/ignition coil
- clogged fuel injector(s) (I doubt it since your CO emissions are high)
- leaking oil into the combustion chambers
- ignition timing
- air filter
I can't think of anything else right now.
Old Jul 27, 2007 | 03:32 PM
HiProfile's Avatar
Default Re: (ddd4114)
By XXX low and XXX high, is the low the limit and high what the car scored? If you gave the requirement and the actual result, I could give you an idea.
Old Jul 27, 2007 | 04:04 PM
ddd4114's Avatar
Default Re: (HiProfile)
I don't know what PA is like, but here in NJ:
Max NOx = 1242
Max HC = 159
Max CO% = 0.89%
dtran002
Nov 21, 2009 11:38 AM
Nine3SiRollin
Apr 21, 2008 03:30 PM
2GEN DA
Aug 2, 2006 07:04 AM
Blackhtch
46
Dec 30, 2004 12:02 AM
88 rex
Aug 16, 2003 06:15 AM
