CEL code : 10 IAT - intake air temperature sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dont_tri »</TD></TR><TR><TD CLASS="quote">Great now my problem is where is the IAT located?
what year civic?
what year civic?
Its one of three places:
Intake arm (d16y8, b16a2)
Intake filter box (d16y7)
Intake manifold (z6, a3, many others)
If you get the code back, after just a reset (probable) clean both ends of the connector (harness and sensor) with electrical contact cleaner or even brake cleaner, then add a blob of dielectric grease (aka bulb grease)
I have a b16a2 99 em1. However, I have a OB1 skunk intake manifold and the sensor was fabricated to fit a sensor that was mounted on the intakemani. I still have the other sensor on the intake arm as well just unplugged.
i guessing you modified the harness not the sensor, I don't know if they are the same, but try swaping the sensor that you have plugged in with the extra one you have in the intake arm or see if you can reroute the harness plug to the one in the arm
