Changed and checked oil, oil is low and no leaks!
Old Jul 26, 2007 | 07:51 PM
meangreenEG's Avatar
Default Changed and checked oil, oil is low and no leaks!
Here's the break down. I changed my oil today, and put 10w30 valvoline fully synthetic oil... Checked the manual and it said 3.5 quarts....so i filled 3.5 quarts...it was low so i emptied the half quart of oil that i had....took the car for a drive, and came back, checked oil and it is STILL low, and no leaks are evident. what could be the cause? It's a 92 civic hatch vx. the oil is not black or anything, its still the caramel color.
Please help....is it me or does my car take more than 3.5 quarts?!
Old Jul 26, 2007 | 07:54 PM
ekb16's Avatar
when u first put oil back in did u check the dipstick to see how much was already in there or did u just put 3.5 qt? wut i usually do is when i first put oil back in, i like to put it alittle past the full mark to compensate for the oil filter
Old Jul 26, 2007 | 07:58 PM
Default Re: (ekb16)
i drained all the oil first, put the nut back on and the oil filter, then filled 3.5 quarts. and the dipstick is all the way in too...the car actually has 4 quarts now.
Old Jul 26, 2007 | 08:18 PM
Default Re: (meangreenEG)
quick bump
Old Jul 26, 2007 | 10:10 PM
egb16pg's Avatar
check your coolant.
and did you feel the clutch slipping?
the main seal could be leaking.
try to peak in your tranny, or take off your inspection plate and look for oil
Old Jul 27, 2007 | 05:51 AM
Default Re: (egb16pg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb16pg &raquo;</TD></TR><TR><TD CLASS="quote">check your coolant.
try to peak in your tranny, or take off your inspection plate and look for oil</TD></TR></TABLE>
Coolant level is normal, and the clutch is not slipping. Where is the inspection plate, and what is the main seal?
Old Jul 27, 2007 | 06:24 AM
instructor74's Avatar
I beleave that that engine with oil filter the capcity is 3.9 qrts oil. I just add 4 qrts start the car check the dip stick and call it a day
Modified by instructor74 at 7:40 AM 7/27/2007
Old Jul 27, 2007 | 06:47 AM
fmrprojects's Avatar
Default Re: (instructor74)
you sure you letting the oil settle before checking or you checking right after you shut off the car
Old Jul 27, 2007 | 07:12 AM
Default Re: (fmrprojects)
i let the car idle for a couple minutes and check the oil. i already have 4 quarts in there. the oil level should be between the 2 holes on the dipstick.... it is below the first hole right now...
Old Jul 27, 2007 | 12:41 PM
Why is my oil still low....anyone else have any solutionsss?
Old Jul 27, 2007 | 12:52 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">Why is my oil still low....anyone else have any solutionsss?</TD></TR></TABLE>
Add oil until the dipstick shows the correct level, and then continue to monitor it at regular intervals.
Old Jul 27, 2007 | 01:17 PM
ap1s's Avatar
Default Re: Changed and checked oil, oil is low and no leaks! (meangreenEG)
Yes, your car does take 3.5 quarts of oil with a filter change. Your transmisson does not have an inspection plug. Some cars like older honda accords have a plug on the trans housing that you can pull out to see the flywheel. Yours however doesn't. Also, if the rear main seal, the seal around the crankshaft at the back of the motor, was leaking, it would be visible under the car if the oil level was that low. Checking the coolant was good. If it was milky looking, you could have had a blown headgasket. Not quite sure why the level is that low. Maybe burning it through the engine? Noticed any excessive blue smoke behind the car under acceleration?
Old Jul 27, 2007 | 05:58 PM
egb16pg's Avatar
Default Re: Changed and checked oil, oil is low and no leaks! (ap1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1s &raquo;</TD></TR><TR><TD CLASS="quote"> Your transmisson does not have an inspection plug. </TD></TR></TABLE>
plug? idk when i said that.but w/e
yea it does, its between the tranny and motor(under by oil pan), remove it and you'll see your flywheel. check for oil.
Old Jul 27, 2007 | 06:01 PM
egb16pg's Avatar
maybe this will help
https://honda-tech.com/zero...54370
Old Jul 27, 2007 | 06:14 PM
LPoke's Avatar
piston ring leak.... j/k you should be good though
Old Jul 27, 2007 | 06:18 PM
akunamatta's Avatar
* B A N N E D *
you should wait a while after the car is running to check the oil.... because it takes a while for oil to drain out of the head etc. dont worry.
Old Jul 28, 2007 | 10:02 AM
themikewoo's Avatar
best guess would be oil leaking past the pistion rings and/or valve guides leaking. so when your on your intake stroke the oil is getting sucked in from the valve past the valve guide
Old Jul 28, 2007 | 11:36 AM
Default Re: Changed and checked oil, oil is low and no leaks! (themikewoo)
i added a bit more oil and the level is fine now.. thanks for all the help.
highwhey
Nov 11, 2010 05:53 AM
Xxcivic99xX
Aug 12, 2004 10:27 PM
Campee
16
May 20, 2003 05:33 PM
Puki
May 19, 2003 11:56 AM
94GsRacer
Sep 19, 2002 02:43 PM
