my Si stumbles in vtec
this is my headache my car is ok until it hits vtec. when it goes into vtec the car starts stumbling like its hitting the rev limiter. i had a CEL and its o2 bank 1 o2 bank 2 low voltage i changed the sensor with NGK's.the 3rd CEL is system to lean im running premium fuel new fuel filter new spark plugs.the motor is a B16A2 if anyone has any ideas please let me know.
im confused...did you change the o2 sensor or replace the spark plugs with NGK's? and also what exactly were your codes because the code you said was more of a run-on of two similar codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 »</TD></TR><TR><TD CLASS="quote">do you have oil? well enough oil that is</TD></TR></TABLE>
yeah that could also cause it, wouldn't cause your engine light but would cause vtec to feel weak due to lack of oil pressure.
billybaggins
Dec 19, 2012 06:19 AM
doubleoazn03
Jun 30, 2011 06:42 PM
