suggestions...b18c5 fuel pump
Old Jul 26, 2007 | 07:03 PM
rewerbcrx's Avatar
Default suggestions...b18c5 fuel pump
is it HIGHLY recomended that i upgrade my fuel pump? ( stock HF tank and pump) running a bored C5 with ctr pistons running a vortech fuel pressure optimizer/fuel rail
i do wanna up grade over the winter but not right now if i don't have to... if i have to then i have to no big deal
Old Jul 27, 2007 | 04:55 AM
rewerbcrx's Avatar
Default Re: suggestions...b18c5 fuel pump (rewerbcrx)
bump... out of curiosity
Old Jul 27, 2007 | 06:15 AM
CRX Toad's Avatar
If you must upgrade here you go
https://honda-tech.com/zerothread?id=1263692
Old Aug 3, 2007 | 02:37 PM
rewerbcrx's Avatar
Default Re: suggestions...b18c5 fuel pump (CRX Toad)
but do i need to ? that is the question... anyone running a similar app?
Old Aug 3, 2007 | 03:42 PM
poundedhatchcrap's Avatar
I dont see why you would need to upgrade the fuel pump in your application. Unless you have considerably larger injectors, that require a upgraded pump I wouldnt worry about it. I dont think your set up will require a new pump, your stock one should do just fine.
Old Aug 3, 2007 | 06:03 PM
true to form's Avatar
Default Re: suggestions...b18c5 fuel pump (poundedhatchcrap)
If your fuel pressure is at an adequate level then you don't need to upgrade just yet. I can tell you though that with that setup you're quickly approaching the upper limit of what that pump can handle so an upgrade would not be a bad idea in the near future.
Old Aug 4, 2007 | 07:29 AM
rewerbcrx's Avatar
Default Re: suggestions...b18c5 fuel pump (true to form)
its a 12.6:1 compression.... just to throw that out there
Old Aug 4, 2007 | 06:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">its a 12.6:1 compression.... just to throw that out there</TD></TR></TABLE>
Again, as long as you're achieving a constant, consistent fuel pressure you'll be alright. Some guys like to run a little on the rich side of things with higher comp like you have. If this is the direction you want to go then, yes, a higher flowing fuel pump, fuel rail and maybe injectors will be needed. Unless you plan on adding more power (and thus need more fuel) your current setup should be just fine until you get the funds to upgrade.
si0385.
Jan 14, 2006 11:51 AM
VspecSiR
May 17, 2004 04:37 AM
Todapwr
May 12, 2004 07:51 PM
Screamer
Jun 18, 2003 09:17 AM
TedR719
Aug 1, 2002 09:40 AM
