Throttle Bodies...
anybody know the stock bore of an itr tb? i have an itr intake manifold on my b16a and i am using the stock b16 tb and am currently looking into which tb to upgrade to. also does anyone know if the spoon tb is a true 70mm? or does it taper down to a different size? thanks in advance
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
the spoon is 70mm inlet and 64mm outlet. if you can find one, bbk also makes a 70mm for the b-series.
since we talking about throttle bodies here, when did they get rid of that little bent pipe right by the TPS sensor, and does the type r throttle body have a straight through 62mm bore or is it tapered!
filipedua
Oct 29, 2010 03:45 AM
REDTOPAlchemy
Jun 23, 2004 10:45 PM
