throttle upgrade
throttle upgrade
hello all,
i am new here. now, i had a question...hope someone can give me an idea.
my car is 98 civic si with b16a. i am now using an itr throttle with itr intake.
now i want to enlarge the throttle and upgrade the throttle plate to 70mm or greater (depends on how large the throttle can enlarge)
did anyone try this....any negative affect to this.
B.rgds
tony
B.rgds
tony
Re: throttle upgrade (tonywyt)
if you increase the size of just the T/B you will only see a couple of HP and really no gains faster wise..if you get the T/B bored to 70MM id get the intake manifold port matched to the T/B and you will see some nice gains..goodluck
adaM
adaM
Re: throttle upgrade (STEALTHMODECOUPE)
ack with many thx.
my itr throttle had already port to a spoon style and the itr intake
manifold had port to very smooth with it's mouth enlarge to 70mm.
however, the throttle plate still using the itr stock size (67mm). so, i want
to port the throttle and enlarge this plate to a greater size. did u had
any idea how large it can large. does this useful ? any negative affert to
the low rpm ?
B.Rgds
tony
the low rpm ?
B.Rgds
tony
i know that if your tb is 70mm straight through and not tapered youre going to loose power on a nat. asp. engine... and even if you get the spoon piece you wont see hp gains just better throttle response. $450 is alotta chedda.
Re: throttle upgrade (euclid)
hello hello,
thx for yr information......but i did not know what is the meaning of
striaght through.....did it mean that without the throttle plate...
besides, i also want to know if there is any hp gain or lost if the throttle
is too large.
thx again for all yr help...
rgds
tony
is too large.
rgds
tony
1st: i assume you welded the manifold to open up the opening to 70mm because
otherwise it would hit the IACV passage
2nd: ITR throttle plate is 62mm
3rd: you will see NO gains by using such a large TB. ITR 62mm is the most ideal
size
size
Re: throttle upgrade (sgT)
hi sgt,
sure, i had welding the manifold and large the opening.
but as yr mentioned, NO gain for larger than 62mm, then
i need to re-consider it as it need about 150 to enlarge
the tb. actually, now i am using the mugen n1 dc2 computer
n is very satisfy. of course, i need more. any good suggestion.
anyway, many thanks.
rgds
tony
rgds
tony
In The Garage
well i could make some rude comment about the suggestion of english lessons, but i wont do that. i could also say something about no 98 si with a B16A (unless youre from canada and swapped in the B16A, since the 98 CA Si had a D16Y8 i think.) anyways, id look more into porting the head and getting a good header, as opposed to spending so much time on the intake manifold.
92integraVTECgsr
10-06-2007 10:21 AM
Daniel-sanB1
06-06-2007 10:10 PM
X2BOARD
15
09-15-2006 04:46 AM
B18Redline
06-03-2002 01:12 PM
