Is this a genuine ITR throttle body? Need measurements/dimensions
Hi mates
I've bought an TB as being from an ITR from an user of this forum. The TB has been delivered and it has not the dimensions of an ITR TB. Seller insists that it belongs to an itr, I know it doesn't. So I've decided to open this thread to help me prove that seller is wrong.
The TB he sent me has the following dimensions:
inlet (intake rubber pipe side):
outer 68mm / inner 63mm
outlet (after butterfly/plenum side):
inner 61mm
Shouldn't a genuine itr throttle body have an inlet of around 67mm and tapered down to 62mm? (both inner dimensions)
inlet outer diameter must be 70+ mm, right? If Spoon or Maxbore can bore it to 70mm opening... The one I've received has at the largest point 68mm, how can they bore it to 70mm opening, for sure it's not an itr TB, it's a regular B16A2 (OBD2) TB.
Please everyone with the knowledge reply to this thread, because I've been scammed and in last case I'll need to prove paypal that the seller is wrong.
Also, the TB has been sold as being JDM, all JDM itr TB have a spout that connects to the charcoal canister, right? The one I've received has not that spout.
Please help
inner 61mm
Please help
Re: ITR Throttle body measurements.
If it was a regular B16/GSR/etc throttle body it would be 60mm ID. A ITR is 62mm. You can look at the bottom of the throttle body, does it have a place for a IACV, or is it just a inlet and outlet port?
It will look like this one.
"does it have a place for a IACV"
Do you mean FITV? The TB I've received doesn't have FITV, it's alike the one in the picture you've post, the only problem is that specifications/dimensions don't match itr TB ones.
Here are some pics of the received TB.
This cannot be an ITR Throttle body, right?
The 62mm that ITR has, is measured after butterfly (plenum side) like in the last photo, right?
No Big Whoop
That is not an ITR TB. Clean the butterfly and take a look at it. If it is an ITR, it should have either 625 or 1JC stamped on it. That one judging by the pics, should have a 660 stamped on it.
Re: Is this a genuine ITR throttle body? Need measurements/dimensions
After all this time user hasn't refund me a cent, complete waste of time and money.
Avoid this user, he's not serious and doesn't have a clue of what is selling
HT Username: Mullen
Paypal account: mullenskater7@netscape.net
other emails: kseriescoupe@hotmail.com
HT Username: Mullen
Daniel-sanB1
06-06-2007 10:10 PM
