Problem with CRX
Old Jul 26, 2007 | 02:36 PM
CCCP-ef's Avatar
Default Problem with CRX
i have a crx HF and i need to put a rear swaybar on it, but there are no nuts on the frame.
should i just weld the brackets to the frame or weld some nuts and make it like OEM?
Old Jul 26, 2007 | 02:38 PM
CCCP-ef's Avatar
would welding to the frame put to much stress on the welds?
Old Jul 26, 2007 | 02:39 PM
Jared's Avatar
welding it to the frame isnt a big deal, just tac it up first and remeasure. undercoat thoroughly when you are finished.
Old Jul 26, 2007 | 02:41 PM
CCCP-ef's Avatar
witch would be easier
Old Jul 27, 2007 | 07:02 PM
zCivic's Avatar
Default Re: Problem with CRX (CCCP-ef)
Not sure about HF but I'm pretty sure there should be holes back there for the rear brackets. I know both of my civic and rexs had them both DXs. The holes were covered with road grime and undercoating but they are there.
Old Jul 28, 2007 | 05:23 AM
driveahonda's Avatar
A lot of the cars did not have the holes. I have had to drill holes myself on several cars to fit a factory fitting sway.
Old Jul 31, 2007 | 10:55 AM
HT Chaplain's Avatar
Loved
Suspesion techniques makes a kit for like $189 that you can get at summitt
Old Jul 31, 2007 | 11:27 AM
ian1006's Avatar
i have the ST kit on my 91 HF and it comes with brackets to bolt to the frame where the tow hooks are. pm if you need pics
Old Jul 31, 2007 | 01:24 PM
Mr.E.G.'s Avatar
check out some of the asr stuff for the hf. they bolt it to the frame.
Corksil
15
Nov 5, 2011 12:11 PM
SupraRXZ
Suspension & Brakes
Jan 11, 2007 06:01 PM
