Duralast vs. Brembo
I need new rotors, so I might as well ask all of you what you think is better... Duralast or Brembo rotors.... and should I get drilled and slotted or just blanks.. by the way I have discs in the front and drums in the back, no ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Duralast</TD></TR></TABLE>
AutoZone/Duralast blanks are fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Even if there is a difference, I'm positive it's minimal. Better pads/fluid would make more of a difference than the difference in those rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Even if there is a difference, I'm positive it's minimal. Better pads/fluid would make more of a difference than the difference in those rotors.</TD></TR></TABLE>
yea what he said
get like ebc green stuff pads or hawk pads
you stop realll good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG »</TD></TR><TR><TD CLASS="quote">So to remove my stock rotors i need to hammer out the screw? I don't wanna strip it.... and how do I put it back on? </TD></TR></TABLE>
it's not just hammering it out. you will need a impact driver. this what it looks like:
http://www.brownells.com/aspx/...=7932
if they do happen to get stripped, because they can and possible will. the easiest way to remove them is to drill them out. unfortunatly i don't have my drill bit set to tell you what size, but it has to be narrow enough to go through the hole on the spindle/hub.
it's quite simple, not as bad as it sounds.
depending on cost get the brembos... I have them on my 91 se-r with metal master pads which I expected to eat up the rotors. two years later the rotors look nearly new.. I doubt that generic rotors would have held up as well. BTW I got the brembos from nopi for a very reasonable price
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
it's quite simple, not as bad as it sounds.</TD></TR></TABLE>
if you do end up drilling it out there is no need to go as far as the hub all you have to do is get the chamfered head to fall off then the rotor will come off. the bolt is m8 so a 5/16 drill bit should work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtlaw1 »</TD></TR><TR><TD CLASS="quote">
if you do end up drilling it out there is no need to go as far as the hub all you have to do is get the chamfered head to fall off then the rotor will come off. the bolt is m8 so a 5/16 drill bit should work</TD></TR></TABLE>
i don't even deal with the impact driver, too time consuming.
Brembo rotors go for about $29 Each.
Duralast Are $27 Each
In this case, I'd say get the brembo's for the $4 difference.
Who knows, it might have a slightly different/better composition.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Brembo rotors go for about $29 Each.
Who knows, it might have a slightly different/better composition.</TD></TR></TABLE>
brembo for $29? where? GIVE THAT LINK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=831188
great place if you're closer to WA than chicago.
you can save a few bucks if you go with 88rotors.
IRP - 29x2 + 22*2 + 18-25(s&h) = 120-127
88 - 65 + 52 = 117
https://honda-tech.com/zerothread?id=1411597
OP: The brembos tend to wear longer if you're going to push the car really hard (ie multiple lap track sessions).
For a street machine that may get pushed from time to time it can go either way, which ever you can get cheaper.
</TD></TR></TABLE>great place if you're closer to WA than chicago.
88 - 65 + 52 = 117
yeah its all about the metallurgy. can't comment on the duralast, but I seen cheap rotors that only last as long as the equally cheap pads thet were used with
</TD></TR></TABLE>yeah its all about the metallurgy. can't comment on the duralast, but I seen cheap rotors that only last as long as the equally cheap pads thet were used with
infinkc
12
Mar 9, 2007 10:10 AM
blacksniper
11
Jul 26, 2004 03:03 PM
tekstyle
Oct 30, 2003 07:26 PM
Doeboy
10
Sep 18, 2003 09:57 AM
