manifold absoulte presure sensor
Old Jul 25, 2007 | 04:53 PM
hazrd420's Avatar
Default manifold absoulte presure sensor
What does the fricker look like???
Old Jul 25, 2007 | 05:12 PM
Allday07's Avatar
Default Re: manifold absoulte presure sensor (hazrd420)
the search button is red for a reason
Your search for map sensor returned 91 results
Old Jul 25, 2007 | 05:20 PM
Crx Jimmy's Avatar
its on the firewall, its a small black thing, a vacuum hose from the throttle body goes to it, there are some round solenoids next to it as well. just follow the vacuum lines till you find it. Unless you have a newer 92+ throttle body which the MAP is on top f it.
Old Jul 25, 2007 | 05:49 PM
hazrd420's Avatar
Default Re: manifold absoulte presure sensor (Crx Jimmy)
that would cause my car to smoke right? if its bad the reason is when i bought the car and got her running,it was disconnected and smoked know its connected and i think it went bad. when i disconnect it she dies on me never happend before.
Old Jul 25, 2007 | 06:53 PM
hondacivic90zc's Avatar
plain and simple the car WILL NOT RUN without the map sensor plugged and working. So whatever was wrong with it before it couldnt of been disconnected.
Old Jul 25, 2007 | 07:04 PM
hazrd420's Avatar
Default Re: manifold absoulte presure sensor (iandavis90)
the vac hose was disconnected
Old Jul 25, 2007 | 07:24 PM
ok that makes sense but what color smoke is coming out.
Old Jul 25, 2007 | 08:11 PM
pandarex's Avatar
if your vacuum hose was disconnected from your map it may smoke a little, but would run like **** more than smoke. like not idle, not accelerate, so on so forth. if the smoke is black your running rich, if its blue your burning oil.
Old Jul 26, 2007 | 03:03 PM
hazrd420's Avatar
Default Re: manifold absoulte presure sensor (pandarex)
the smoke is whiteish??
Old Jul 26, 2007 | 03:34 PM
STREETWERKZ's Avatar
white smoke sounds like headgasket.
Old Jul 26, 2007 | 04:18 PM
hazrd420's Avatar
Default Re: manifold absoulte presure sensor (STREETWERKZ)
but doesn't smell sweet.
bLu92bUbbLe
Jul 6, 2009 12:00 AM
chris3385
Jan 3, 2009 04:49 AM
PearlBlueType-S
Jan 7, 2006 09:27 AM
93civiccxhatch
Nov 6, 2004 06:37 PM
