brake problems
Old Jul 25, 2007 | 02:29 PM
fbw2003's Avatar
Default brake problems
ok heres the story i started to get more and more free travel in my brake pedel and now it goes like 2 or 3 inches from the floor before it really grabs good. i have bleed all the line for air but i think it is somehting else. need some help.
Old Jul 25, 2007 | 02:44 PM
garageEF's Avatar
Default Re: brake problems (fbw2003)
replace the master cylinder.
Old Jul 25, 2007 | 02:49 PM
fbw2003's Avatar
Default Re: brake problems (garageEF)
the master cylinder is only about 3 years old
Old Jul 25, 2007 | 03:02 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fbw2003 &raquo;</TD></TR><TR><TD CLASS="quote">ok heres the story i started to get more and more free travel in my brake pedel and now it goes like 2 or 3 inches from the floor before it really grabs good. i have bleed all the line for air but i think it is somehting else. need some help.</TD></TR></TABLE> Check for leaks @ the MC and Prop valve where the hardlines screw in.
Old Jul 25, 2007 | 03:15 PM
fbw2003's Avatar
Default Re: brake problems (89efDUSTY)
no leaks but im going to try and power bleed it and if that dosent work i guess ill try a master cylinder
Old Jul 26, 2007 | 08:02 AM
fbw2003's Avatar
ok i replaced the master cylinder and bleed the brakes again it was feeling a lot better when we were bleeding them. it felt like i had a pedal but when i started it up it was still going almost to the floor before it would start to grab. i need some help.
Old Jul 26, 2007 | 08:30 AM
CRX Toad's Avatar
Wheel cylinder leak? Or you still have air in the lines.
Old Jul 26, 2007 | 09:09 AM
fbw2003's Avatar
Default Re: brake problems (CRX Toad)
ya i have replaced the one that was leaking but i think from eveything that im reading that it was to be air so im gonna get a power bleeder and see what happens.
Old Jul 26, 2007 | 09:29 AM
ozrednsx's Avatar
have you taken off your calipers for any reason?
If so make sure you have placed the right caliper on each side...it should be stamped L and R...
You can tell if its on the wrong side if the nipple that you are bleeding is facing towards the bottom. Remember air rises and if the nipple isnt on the top you wont be able to get all the air out.
...bench bleed the MC also
justforkicks
Sep 10, 2006 11:47 AM
bb4socal
Sep 4, 2006 09:51 PM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
GReddy SI
Jul 17, 2003 09:36 PM
CRX7
Nov 3, 2002 09:17 PM
