spark plugs for 400-500 hp
Old Jul 25, 2007 | 12:41 PM
powerdbygarrett's Avatar
Default spark plugs for 400-500 hp
what spark plugs are u guys using for 400-500hp cars. how much colder should they be. they are going in an h22. if someone could give me a part number for the proper nkg plugs that would be great. thanks!
Old Jul 25, 2007 | 12:45 PM
RTW DC2R's Avatar
2 posts down... https://honda-tech.com/zerothread/2051678
or search
Old Jul 25, 2007 | 01:55 PM
im not trying to read through that entire thread if u can just give me a strait and simple answer that would be great thanks
Old Jul 25, 2007 | 03:56 PM
turbod da's Avatar
Default Re: (powerdbygarrett)
i use ngk #9 600hp+ here with no problems..gap them at .028
Old Jul 25, 2007 | 06:36 PM
morgan@synapse motorsport's Avatar
Default Re: (92gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gs &raquo;</TD></TR><TR><TD CLASS="quote">i use ngk #9 600hp+ here with no problems..gap them at .028</TD></TR></TABLE>
those will foul out fast on his setup you shoudl just use a 7 if spark is blowing out switch to an 8
Old Jul 25, 2007 | 06:53 PM
93hatched_projekt's Avatar
Default Re: (mike@synapse motorsport)
The plugs your looking for are stock # 3330 ( bcpr7es) . I'm making 450 whp on my h22 daily .
Old Jul 25, 2007 | 07:38 PM
thanks
Old Jul 26, 2007 | 03:21 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">im not trying to read through that entire thread if u can just give me a strait and simple answer that would be great thanks</TD></TR></TABLE>
stop being lazy
anyways, good old copper bkr7e is the plug you want. ngk stock number 6097. the bcp will work as well. might want to go to 8's after 500whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">
just use a 7 if spark is blowing out switch to an 8</TD></TR></TABLE>
i dont think heat range will really affect spark blow out. reducing the gap will fix that. heat range has to do with keeping the tip at the correct temp to avoid fouling and pre-ignition.
Old Jul 27, 2007 | 07:15 AM
what gap should i start with the with 7's?
Old Jul 27, 2007 | 07:31 AM
RTW DC2R's Avatar
SEARCH
Old Jul 27, 2007 | 09:43 AM
dpetro1's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
seriously its not that hard.
https://honda-tech.com/zerothread?id=2033634
https://honda-tech.com/zerothread?id=1654537
https://honda-tech.com/zerothread?id=1613652
https://honda-tech.com/zerothread?id=1557719
https://honda-tech.com/zerothread?id=1111447
i could go on.
edit: straight from the FI FAQ. https://honda-tech.com/zerothread?id=877602
cvccr
Jun 15, 2007 11:21 AM
Boosthead
Dec 11, 2006 04:56 PM
Nicks95GSR
Nov 30, 2006 10:42 PM
civicracingteam
Feb 17, 2005 03:41 AM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
