Z6 IM on Y7?
Old Jul 25, 2007 | 10:39 AM
sky9's Avatar
Default Z6 IM on Y7?
just wanted to know if a Z6 IM will fit on a y7.
Old Jul 25, 2007 | 08:56 PM
hondamark35's Avatar
Default Re: Z6 IM on Y7? (sky9)
all d-series manifolds (intake and exhaust) will bolt up.
you'll have to figure out hoses and wiring with certain IM's.
with this one you have to use your y7 TB.
Old Jul 26, 2007 | 11:48 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
i would suggest an automatic y8 manifold depending on your setup...that way you can use the stock throttlebody and 3-wire iacv, plus have an ecu that can control the iacv.
unless of course, you only have a y7 motor in another car...or there is a way to control the 2-wire iacv with the y7 ecu that i dont know about...
Old Jul 27, 2007 | 05:12 PM
Default Re: Z6 IM on Y7? (fastcrxsi90)
actually the manual y8 manifold is more versatile. it has the 2pin iacv on the back just in case you decide to do a mini-me or something like that later. just reuse the y7 TB with it and make sure you take a close look at the TB gasket before you put it together.
i think you have to use the y8 gasket... but i can't remember so just look. the wrong one leaves a gap on the lower side of the TB
Old Jul 28, 2007 | 10:39 AM
builthatch's Avatar
MiG-21 superfan
Default Re: Z6 IM on Y7? (hondamark35)
http://www.d-series.org/forums...45024
SOHC_civic_si
May 4, 2008 08:50 PM
honda616
11
May 20, 2007 01:51 PM
vegaskurt
15
Mar 9, 2005 02:52 PM
fishnfst
10
Aug 13, 2003 12:03 PM
