Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Overheating issue?
Old Jul 25, 2007 | 09:09 AM
Bourdoncivic's Avatar
Default Overheating issue?
I have a 2003 civic ex. I've brought it to my local mechanic for overheating. He believed it was a blown head gasket or a pinhole in my water jacket. He suggested i bring to the honda dealership for a warranty issue. The dealership had my car for two days and could not get the problem to occur. They re-burped the coolant system and told me to try it out. About four days later my car overheated again and i returned to the dealer. The dealer has now had my car for another two days and still cannot duplicate the problem. What my mechanic did note was that when the car was cold with the radiator cap open the coolant began to bubble out. He believes the water jacket is taking on a slight amount of compresson from the engine. So If any one has an idea to what it could be let me know because i'd like to avoid spending four hundred bucks to tear off the head.
Thanks,
JB
Old Jul 25, 2007 | 09:16 AM
CivicInspired's Avatar
Default Re: Overheating issue? (Bourdoncivic)
Thermostat.... get it replaced. and never take your car to the dealership
Old Jul 25, 2007 | 10:59 AM
Default Re: Overheating issue? (CivicInspired)
thanks
Old Jul 25, 2007 | 11:08 AM
sujak's Avatar
are you boiling coilant?
Old Jul 25, 2007 | 11:11 AM
PoMoNa_909_eM2's Avatar
i had this same problem it was my head gasket............get it replaced u might not believe it but trust me after head gasket is replaced then everything is fine im prtty sure u get an overheating randomly...here and there rite? some others in here had the same problem too... our motor sucks
Old Jul 25, 2007 | 12:33 PM
go get a pressure test for leaks... if there are no leaks then its prob the thermostat....
after a 4 hour drive back from ImportAlliance, I got a mile from my house and my car started over heating... I had no leaks at all.... no fluid on the ground either so replaced thermostat and it fixed it.
Old Jul 25, 2007 | 02:33 PM
Default Re: Overheating issue? (PoMoNa_909_eM2)
well i just had the thermostat done, when the engine was warm (a little lower than half way on my gauge) i popped the hood. I observed a couple things, a few spots of fresh coolant around the cap for the overflow, and the coolant was bubbling inside of the overflow tank. I don't know if the overfilled it a small amount or if i am still having problems.....
JB
Old Jul 25, 2007 | 02:42 PM
I had two compression tests done on my engine man and it passed both. Not to say that there isn't a pinhole leak in the water jacket right? I also just had the thermosatat done a few hours ago and had about a thirty minute drive home. It didn't overheat but when i pulled into shaws in my hometown i popped the hood for giggles. The coolant was bubbling inside the overflow resevoir, it wasnt intense but it was noticable. Is that normal to see?
Old Jul 25, 2007 | 02:49 PM
sujak's Avatar
you sir need a new headgasket
Old Jul 25, 2007 | 02:54 PM
Default Re: (sujak)
so the bubbling must be the pressure being pushed from the cylinders right?
Old Jul 25, 2007 | 05:29 PM
iGGY366's Avatar
Default Re: (Bourdoncivic)
blown head gasket
Old Jul 25, 2007 | 05:42 PM
rushbuster70's Avatar
blown head gasket like everyone says...same thing happened to me man...
Old Jul 25, 2007 | 08:49 PM
Boilermaker1's Avatar
You need to do a leakdown test, not a compression test, and I guarantee you its the head gasket. If there's no leaks in the cooling system itself, theres only one other place that air can get in......
Old Jul 26, 2007 | 02:56 AM
thinknology's Avatar
Another thing you can check for to see if it's the head gasket... oil in the coolant or... coolant in your oil... or if your burning antifreeze... if you have any of these then the headgasket is the likely problem
Old Jul 26, 2007 | 11:53 AM
its best to just replace the headgasket then keep wasting money to replace this and that....
Old Jul 26, 2007 | 11:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoMoNa_909_eM2 &raquo;</TD></TR><TR><TD CLASS="quote">its best to just replace the headgasket then keep wasting money to replace this and that....</TD></TR></TABLE>
but remember before you go tearing apart your head all day long or taking to the shop and emptying your wallet (or for more parts) make sure you find out what the problem is
Old Jul 26, 2007 | 02:18 PM
Default Re: Overheating issue? (thinknology)
yeah i gave this information cuzz ive been through it and trust me i replaced here and there and everything you can think of that causes the car to over heat and at the end replacing the head gasket .....the car stopped overheating...
Old Jul 26, 2007 | 03:55 PM
MatterMatt's Avatar
Default Re: (CivicInspired)
Only replace the thermostat if the upper hose is hot and the lower is still cold after the car is at normal operating temp. Do a compression/leak down before tearing the head off.
Old Jul 27, 2007 | 03:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoMoNa_909_eM2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i gave this information cuzz ive been through it and trust me i replaced here and there and everything you can think of that causes the car to over heat and at the end replacing the head gasket .....the car stopped overheating...</TD></TR></TABLE>
lol been there done that... i wont even think about buying anything now until im 100% sure
Old Jul 27, 2007 | 12:12 PM
Dbol18's Avatar
I got a question guys... My engine is overheating when stationary, started happening last night first time.... but as soon as Im moving its fine... goes way below 50% on the temp gauge in the car... Thermostat? A tech told me he thought it was my fans, but they sound and look just fine..... HELP?
Jmarelt
Mar 12, 2016 08:32 AM
14psi
May 15, 2013 07:29 AM
flyin_peewee
Dec 14, 2009 01:22 PM
runwitme
14
May 17, 2009 04:16 PM
master honda tech
Sep 7, 2004 12:34 PM
