Dent pulling
Old Jul 24, 2007 | 07:40 AM
awdgsx96's Avatar
Default Dent pulling
This is my first time in here, so be eay on me. I've done some searching but need to better learn how to pull dents with a electrode + slide hammer.
Here is my thread in the Accord forum:
https://honda-tech.com/zerothread/2051027
Does anybody have any secrets to using the manner of dent pulling? Somebody in my other thread also mentioned dry ice. I would like to learn, there isn't alot on the interweb about it, at least that I could find
Old Jul 25, 2007 | 08:20 AM
Lost_clearance's Avatar
Default Re: Dent pulling (awdgsx96)
what dients are yuo pulling where are they and how bad?
using a stud gun (what you just discribed) is not that great idea, unless there is no possible way to get inbehind it, beucase it burns the protecting barrier off and will eventually rust, also it can apply to much heat
You want try using the hammer off dolly method and that should raise it, just work away with it and keep blocking it out, just dont stretch the metal to much
Old Jul 25, 2007 | 11:33 AM
awdgsx96's Avatar
Default Re: Dent pulling (Lost_clearance)
Reference the thread link I posted before, the pic of the dent is towards the bottom of the page.
The problem is I can only do so much with the hammer and dolly because of the double paneling and the fact that I don't even know where the high and low spots are supposed to be.
I went to a junkyard today that allows you to cut stuff so I'm going to cut out the quarter and reweld.
Old Jul 25, 2007 | 06:36 PM
sc4dr's Avatar
Bad idea. Unless your an experienced bodyman, I would not attempt to reuse a used quarter panel, more less a new one.
Old Jul 26, 2007 | 06:13 AM
awdgsx96's Avatar
Default Re: Dent pulling (sc4dr)
Why is that?
Asking because this is only a project car, I got it for $50, I kinda wanna see what I can learn from it.
Old Jul 26, 2007 | 04:24 PM
sc4dr's Avatar
Well, if thats the case go for it. Just make sure the quarter is on safe. Welding auto sheetmetal is tricky.
Old Jul 26, 2007 | 04:33 PM
awdgsx96's Avatar
I know. But luckily my dad is an experienced welder and I have alot of time welding with him and from taking it for a year in school.
I'm guessing I would use the mig. Should it be done in spot welds or full beads?
Old Jul 26, 2007 | 07:27 PM
just make sure you use like 0.0023 mig wire and set it low other wise it will be holes, he is right it is very hard but where you wil lbe welding it might be easier
Old Jul 26, 2007 | 08:18 PM
awdgsx96's Avatar
Default Re: (Lost_clearance)
I'm hoping so and thanks for the input guys
Old Jul 27, 2007 | 03:29 PM
sc4dr's Avatar
Default Re: (awdgsx96)
I use 23 mig wire, but I like to weld hot(high setting), because it lays a flat strong weld(penetration is key). You would use plug/spot welds on the edges/pinch areas, and stitch weld across your rocker panel, and sail panel. Good luck
Old Jul 27, 2007 | 04:33 PM
awdgsx96's Avatar
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">I use 23 mig wire, but I like to weld hot(high setting), because it lays a flat strong weld(penetration is key). You would use plug/spot welds on the edges/pinch areas, and stitch weld across your rocker panel, and sail panel. Good luck </TD></TR></TABLE>
This is probably going to sound bad. What is the sail panel?
Old Jul 29, 2007 | 06:45 AM
sc4dr's Avatar
The sail panel is where the quarter panel meets the roof. Most people would have asked that question, I'm just so used to talking technical terms day in and day out working at a high volume body shop.
Old Jul 29, 2007 | 02:30 PM
awdgsx96's Avatar
Default Re: (sc4dr)
Ahhhhh, ok thank you
jdeacon
Jul 18, 2010 03:57 PM
JSPECxSEDAN
Nov 16, 2009 07:30 AM
EJ8VTEC
Acura TSX
Nov 28, 2008 07:06 PM
Luserkid
Welding / Fabrication
Nov 14, 2006 08:04 AM
AxisAccord
Jul 15, 2005 07:10 PM
