Honda S2000 Honda S2000
Driving down the road and my S2k just stops!
Old Jul 24, 2007 | 12:01 AM
6KVtec's Avatar
Default Driving down the road and my S2k just stops!
Ok so i just got my 01 S2k and its been running great for the first day, as im going home i go from 6th to 4th and get on it, after i do that the car decides it does not want to run anymore...so i let it sit for about 10 minutes and it starts up and runs the rest of the night...now before i bought this car the previous owner had a supercharger on it with a piggy back ECU on it...however he took it off and i reset the ECU from the battery...i just need some help on what this dam problem could be!
Old Jul 24, 2007 | 08:11 PM
ProjectDarkBlack's Avatar
Default Re: Driving down the road and my S2k just stops! (6KVtec)
loose battery cables/grounds would be the first to check. Then check the wires at the ecu. Test the ignition wire too
Old Jul 24, 2007 | 08:22 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Driving down the road and my S2k just stops! (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">Then check the wires at the ecu. </TD></TR></TABLE>
All 100+ of them? Sweet!
OP: Conditions? Car fully warmed up? Year/mileage/mods?
Old Jul 24, 2007 | 08:29 PM
LemurFaktore's Avatar
Default Re: Driving down the road and my S2k just stops! (Mr. Projekt)
well...considering that when you went from 6th to 4th and it bogged out...
if i was in your position, i'd probably run codes and try to find freeze frame data....that is if you have access to scan tools....
but w/o one.....just check basics: ground, fuel, fuel pressure, spark, etc.
however he took off the piggyback....obviously he probably did some wiring mod close to the ecu...check the wires there....and with a piggyback, i highly doubt he spliced into 100 wires....just look for ones that stand out (like they've been messed with) and make sure the connection is good...
if those check out..well ur gonna need a scanner
good luck
Old Jul 24, 2007 | 08:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
OP: Conditions? Car fully warmed up? Year/mileage/mods?</TD></TR></TABLE>
no just the several that are twisted together and covered in electrical tape
Old Jul 24, 2007 | 11:26 PM
6KVtec's Avatar
cool cool, thanks for all of your posts i think i have an idea of what to look for now...Thanks!
Old Jul 25, 2007 | 01:40 AM
silvermys2000's Avatar
If u are throwing a code just go to a autozone or discount auto parts store and they will check it for free
Old Jul 25, 2007 | 05:08 AM
JDM knowledge's Avatar
Default Re: (silvermys2000)
that must have been the same time your car saw my car and it was like "DAYYYUMMM" and shut down in awww.
good luck.
LBCREEP
27
Mar 29, 2008 02:03 PM
egbaby
Feb 24, 2008 12:30 AM
UNDER PRESSURE
Nov 24, 2005 09:04 PM
esoterEK..
Mar 9, 2004 01:20 PM
halfNhalf-83
Nov 27, 2003 09:29 AM
