Ek Not Starting, and no fuel pressure
Old Jul 23, 2007 | 09:20 PM
slimjimdanny's Avatar
Default Ek Not Starting, and no fuel pressure
i just finished swapping over the 1993 civic si motor onto my 1999 civic dx. i used the dx harness and extended a few wires... the problem is i cant seem to start the car and i cant hear the fuel pressure rise at all.. what is the problem here? the ecu that i am using for now is a 99 dohc si ecu... the motor doesn't make any noise when i try to start the car. any suggestions ? ????
Old Jul 23, 2007 | 09:28 PM
red02s2k's Avatar
check all your grounds... loosen the fuel filter a little see if there is air in the line if you think it is a fuel problem..
Old Jul 23, 2007 | 09:44 PM
w0ng_sta's Avatar
Default Re: (red02s2k)
do u hear the relay clicking? search up relays and your fuel pump
Old Jul 24, 2007 | 12:52 AM
ru7's Avatar
ru7
Check the fuse box if all are good. Maybe some fuse blown while extending wires...
Old Jul 24, 2007 | 04:06 AM
monicle's Avatar
Default Re: (ru7)
my guess is bad wiring, bad main relay, bad fuel pump. in that order
Old Jul 26, 2007 | 01:22 PM
Default Re: (monicle)
thanks guys imma go check all of the above and i will get back with the news
ef9itb
Jan 19, 2010 10:48 AM
stkinge
Nov 21, 2009 08:38 AM
urithium
Oct 4, 2009 01:19 PM
teknohatchie91
Apr 15, 2009 11:40 AM
StraightCivic
Apr 24, 2006 03:58 AM
