Ek Not Starting, and no fuel pressure
i just finished swapping over the 1993 civic si motor onto my 1999 civic dx. i used the dx harness and extended a few wires... the problem is i cant seem to start the car and i cant hear the fuel pressure rise at all.. what is the problem here? the ecu that i am using for now is a 99 dohc si ecu... the motor doesn't make any noise when i try to start the car. any suggestions ? ????
check all your grounds... loosen the fuel filter a little see if there is air in the line if you think it is a fuel problem..
Re: (red02s2k)
do u hear the relay clicking? search up relays and your fuel pump
Check the fuse box if all are good. Maybe some fuse blown while extending wires...
Re: (ru7)
my guess is bad wiring, bad main relay, bad fuel pump. in that order
Re: (monicle)
thanks guys imma go check all of the above and i will get back with the news
