H2B DA Integra questions
Hi all,
I've just found that some kit are made to fit H22A engine that I love in DA Integra. I want to do some lapping/autocross with the car. Here's my questions:
1- Will I be able to keep the Power Steering system???
2- Will this motor that is heavier than a B-Serie will affect a lot in lapping/autocross?
3- Would I be able to use YS1 LSD Cable tranny with this?
4- The H22A is 35lbs heavier than a B-Series engine, will I be able to take around 35lbs of the front with weight reduction? (JDM Front bumper suport, CF hood, A/C removal .etc)
Thanks a lot!
Modified by Silchuki14 at 9:48 AM 7/24/2007
Thanks a lot!
1- I'm going to says no, but may be possible if you made new hoses to go to the pump. With the way the car handles, I would just go without.
2- No. Race track suspension will make this change negligible.
3- Yes. If it is the B16 high gear model, it will make the H22 VERY fun to drive.
4- Yes. CF hood, JDM support, no A/C will lost the 35lbs and probably about 10lbs more.
Root79
May 26, 2003 06:41 AM
