oil pressure guage: mechanical or electrical?
thats what im leaning torward, since its a direct reading. its the install and having oil lines into my car that worries me.
i have had both the mechanical and electrical in my car, the readings i had were ientical in my car with the CRVTEC, it a bitch with the mechanical to put in because you need to feed a line inside the car, obviously. Also you don't want to use the rubber line they give you so i used a steel braided line but like i said pain in the ***. The reason why i took it out was because this guy i new wnated to buy it from me for like 30 bucks more then i paid for it well also i included the steel braided line with it, which i got for free ($30 dollar value) and my other friend gave me his oil pressure gauge (electrical), also another reason why I wanted to switch was because of the fact if the gauge breaks or anything there is oil everywhere in the car. But i got the same readings from both gauges and electrical is alot easier to install. hope that helps
I ran all electrical Auto Meter gauges in me G2 oil pressure, fuel pressure, water temp. It is easier to run wires than it is lines not to mention safer.
Vtak
Apr 29, 2005 11:24 AM
Nextelbuddy
Jul 13, 2003 07:44 PM
