Oil leaking from exhaust
Old Jul 23, 2007 | 05:56 PM
SD99GSR's Avatar
Default Oil leaking from exhaust
Hey has anyone had this problem, right now I'm losing about a quart of oil a week and it appears it's leaking out the exhaust. I'm getting a lot of oil spray all over my rear bumper. Anybody have any idea what can cause this?
Old Jul 23, 2007 | 06:14 PM
hard charging 929's Avatar
Default Re: Oil leaking from exhaust (SD99GSR)
I'm thinking it's valve seals and or your oil control rings aren't clearing the oil off the cylinder walls which will result in loss of oil.
Old Jul 23, 2007 | 07:17 PM
SD99GSR's Avatar
Default Re: Oil leaking from exhaust (agoldenau)
I just got a valve adjustment at the dealer, but i'm still getting spray. Should this have remedied this? Sorry I don't know a lot about engine work.
Old Jul 23, 2007 | 08:09 PM
dark_samurai73's Avatar
bad piston rings will let oil into the combustion chamber, any unburned oil will come out of your exhaust, or if your turboed your turbo could be bad, ive had to chang a few out of cars for just this reason
Old Jul 23, 2007 | 08:23 PM
roastbeefrichie's Avatar
Default Re: Oil leaking from exhaust (dark_samurai73)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dark_samurai73 &raquo;</TD></TR><TR><TD CLASS="quote">bad piston rings will let oil into the combustion chamber, any unburned oil will come out of your exhaust</TD></TR></TABLE>
i agree. do a leak down/compression test, the #'s should be (more or less) the same across the board on all cylinders, your rings are good. but, if the #'s are different, then you're probably going to need to dump the rings & hone the block
Old Jul 24, 2007 | 01:22 PM
Default Re: Oil leaking from exhaust (roastbeefrichie)
agreed with both above posts. The valve adjustment won't affect your issue. But, if you do the compression and leakdown and they are okay, i'd look into your vavle seals leaking.
Old Jul 24, 2007 | 03:36 PM
SD99GSR's Avatar
Thanks guys for all the help, I'll get those test done soon.
EL TYPE R
May 8, 2010 06:22 AM
x_doug-x
11
Apr 1, 2008 10:56 PM
94DB8
Feb 20, 2008 04:28 PM
JDM B16A
Jul 25, 2006 07:57 PM
kihun_cha
Jan 2, 2006 07:45 AM
