wheel alignment Problem!! Please read
Old Jul 23, 2007 | 05:28 PM
BoRiCuA's Avatar
Default wheel alignment Problem!! Please read
Ok i'm posting this topic for a friend of mine who just got his car alignment done by tire kindom. He knows nothing about cars so he asked me to take a look at it for him, I did and i couldn't believe what I was looking at.
The car is driving down the street straight but the car looks CROOKED way crooked. He is looking for the alignment sheet but any clue as to what could be the problem? quick note i saw the sheet just yesterday and almost every square is Red especially the rear toe is not even displayed on the blockhas an x
Old Jul 23, 2007 | 05:36 PM
MatterMatt's Avatar
Default Re: wheel alignment Problem!! Please read (BoRiCuA)
Looks "crooked"? What do you mean? If it is pulling or there is some other obvious problem tell him to take it back. If he had it in and it still is not right then they will have to deal with it.
The printouts usually show before and after measurements. You would see red squares or numbers, but there should be green ones too (unless the tech didn't save the after measurements and just printed the initial measurements).
Anyway, just take it back.
Old Jul 23, 2007 | 05:55 PM
akunamatta's Avatar
* B A N N E D *
sounds like the steer ahead was'nt done.
Old Jul 23, 2007 | 06:01 PM
BoRiCuA's Avatar
Default Re: (akunamatta)
All the blocks are red except for 2, say you are looking at the car drive away and your directly behind it , it's going straight down the line but the car looks crooked sort of like this / but going straight. he's looking for the sheet.
Old Aug 4, 2007 | 07:37 AM
BoRiCuA's Avatar
Default Re: (BoRiCuA)
This is what they gave him after they finished ans still charged him...
Old Aug 4, 2007 | 07:57 AM
rebuiltSI's Avatar
just buy a new car.. jk sorry i dont have any good info for that.
Old Aug 4, 2007 | 08:32 AM
BoRiCuA's Avatar
Default Re: (rebuiltSI)
Well i just replaced his shocks and springs and checked over everything, he's going to get a camber kit next, we'll what happens but he's about had it with this.
Old Aug 4, 2007 | 10:56 AM
EvilPhu's Avatar
The reading don't even look like it's been worked on, it's just the spec on the car as is, maybe the tech forgot to fix it. Otherwise the car is total out of wack,and alot of part are bent.
Old Aug 4, 2007 | 11:03 AM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA &raquo;</TD></TR><TR><TD CLASS="quote">
This is what they gave him after they finished ans still charged him...</TD></TR></TABLE>
Oh wow
Even without camber kits, you can still adjust the toe. It looks like they didnt even do anything. Take it back. I just did the alignment on mine and I am lowered 2 inches with a camber kit in back. I still was able to put everything to spec except the front camber, which is ok because the total toe is fine. Take it back and ask them why the measurements are like this.
Old Aug 4, 2007 | 02:57 PM
BoRiCuA's Avatar
Default Re: (cambopheonix56)
yea he is going to take it back and ask for a refund or try again.
Old Aug 5, 2007 | 07:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA &raquo;</TD></TR><TR><TD CLASS="quote">yea he is going to take it back and ask for a refund or try again.</TD></TR></TABLE>
Let me know the outcome, I am curious to see how they handle this.
Old Aug 5, 2007 | 08:37 PM
hondastrtracr's Avatar
Sounds like a toe problem. Maybe they didn't tighten the rear adjusters back up. My car is sittin 2 inches lower than stock, other than occasional rubbing I can't complain. I have a good alignment guy also. I have a right drift while on the highway, he said it was due to a slightly bowed front lca, I know where the replacements are but 400 is a little steep. Let me know what u find out.
mvp97gsr
Feb 21, 2006 09:27 PM
beater90accordlx
Feb 14, 2005 03:21 PM
acuraLSSE95
Sep 25, 2004 04:35 PM
benmasters
Jan 26, 2004 09:39 AM
Mag00n
Aug 29, 2003 12:54 PM
