Car is cranking, but won't turn over.
Old Jul 23, 2007 | 05:28 PM
em2ssm02's Avatar
Default Car is cranking, but won't turn over.
Well, the battery has juice, its cranking but it doesnt want to turn over.
It started when i was doing a compression test a few days ago, could the plugs have gone back possibly grounding on something? I would assume its something electrical such as plugs or dizzy.
How do i check what it is?
Old Jul 23, 2007 | 06:12 PM
abnaasefmb's Avatar
Default Re: Car is cranking, but won't turn over. (em2ssm02)
you probably fried the coil, did you unhook the dizzy when doing the comp test?
Old Jul 23, 2007 | 06:19 PM
em2ssm02's Avatar
no i didnt unhook it, but im going turbo as soon as i figure out what this was, the reason i did it in the first place was to check the rings, i had to replace them and i threw it all back together.
how would i check to see if the coil is fried? if thsi helps at all it was going fine and when i did the comp. test it would crank and everything then i tried to start it afterwards and it wouldnt turn over, but everything else would go.
Old Jul 23, 2007 | 06:24 PM
abnaasefmb's Avatar
Default Re: (em2ssm02)
replace it. i did the same thing once, but i just changed the whole dizzy because i had one. i think it was the coil, but i don't know for sure, it's just my guess.
Old Jul 23, 2007 | 06:27 PM
em2ssm02's Avatar
well ill be switching over to obd1 currently obd0, so ill be switching dizzy's. should i borrow someones or something cause i really dont want to buy one to use for testing purposes
fastcrvi
Jun 25, 2008 02:50 PM
hackish
Sep 13, 2005 12:44 PM
limey156
Aug 22, 2005 05:39 AM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
mugenracer
May 19, 2002 02:29 PM
