d16y7 swap to d16y8 ?s
Well i have a 98 dx coupe and i was wondering if that swap was a plug and play? I purchased a 2000 d16y8 i did the swap and now im plugging ever thing back in? If any information could help. For on thing im missing my throttle body and was wondering if i can use a b16 obd2 one on the d16? besides the v-tech wiring what other wires do we need to wire? Thank for any help....
I did a swap kinda similar to this a few months ago...
There are going to be a few minor snags you'll run into--I lucked out on the IACV since I was doing from a d16y8 auto to a d16y7 longblock, keeping the y8 IM.
Read this thread, PM me if u have more questions.
https://honda-tech.com/zerothread?id=1938138
None of it should be anything you can't handle. Make sure you have the correct ECU and fuel injectors for the y8.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">with a mini-me, would it be pointless to keep your old TB/IM? I am using and intake manifold from a D15B7 on a D16Y7.. If I change the head/ecu.. no good on keeping the old stuff? </TD></TR></TABLE>
lol threadjacker... why would you have to get rid of the tb and im? they are interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHB »</TD></TR><TR><TD CLASS="quote">I did a swap kinda similar to this a few months ago...
None of it should be anything you can't handle. Make sure you have the correct ECU and fuel injectors for the y8.</TD></TR></TABLE>
thanks man! my friend really need some advice. any more suggestions would be nice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchnideas »</TD></TR><TR><TD CLASS="quote">
lol threadjacker... why would you have to get rid of the tb and im? they are interchangeable.</TD></TR></TABLE>
because the map sensor is mounted differently from he y7 to the y8.
I might have it backwards, but y7's have the map on the TB and y8's on the firewall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
I might have it backwards, but y7's have the map on the TB and y8's on the firewall.</TD></TR></TABLE>
nope only 88-91 civics and 92 Egs had the map on the firewall
as for the op get a 96-98 Ex engine harness and ecu and it is ALL plug and play
lol my ideas from his post, isnt a mini me a vtec head swap? also sounded like he already has the b7 intake mani on a y7 in which case he should already have fixed the sensor issues... that is unless he just worded it goofy and i cant comprehend him.
Dont forget that the IAC in the y7 is the 3 wire, whereas th Y8's is the standard 2 wire. 2 different modes of operation, so it would be best to swap a wiring harness from a y8 as well, its not a whole lot different from the y7, cept for the fact that its wired for the 2-wire IACV, and the VTEC solonoid.
Would save you allot of time by swapping a y8 harness as well, granted you can find one for a cheap price.
If not, you will have to convert the IACV plug yourself, as well as wire up VTEC yourself.
The 96-97 d16y8 w/ AutoTrans is a 3-wire unlike its brethren. Don't ask me why...
This saved me some hassle when my old y8 broke a rod. I put in a cheap y7 longblock with a y7 A/T ECU. Since I re-used the y8 manifold and its IAC, no wiring was needed, which is always nice.
from https://honda-tech.com/zerothread?id=1863277
"the Y8 engine use a 2-wire IACV whereas your Y7 engine uses a 3-wire IAC. The Y7 ecu looks for a 3-wire IACV. So if you try using your DX ecu on a Y8 engine, you're going to get a check engine light for the IACV because the Y8 doesnt use a 3-wire IACV. BTW, the IACV on a Y7 engine is integrated on the throttlebody; the Y8 IACV is seperate and located on the backside of the intake manifold. Altho, an AUTO Y8 intake manifold uses a 3-wire IACV!"
