China Intercoolers
Old Jul 23, 2007 | 03:49 PM
b16a4's Avatar
Default China Intercoolers
How many of you using cheap china intercoolers, and what whp do you have?
Old Jul 23, 2007 | 10:26 PM
RCautoworks's Avatar
Default Re: China Intercoolers (b16a4)
Had a few customers hit 300hp on 7psi. You will pretty much see the effect when you test them and have a read out of the intake temp. I believe someone just did this and the difference was 20 degrees cooler ( with the name brand )
Old Jul 23, 2007 | 11:25 PM
akira712's Avatar
Default Re: China Intercoolers (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Had a few customers hit 300hp on 7psi. You will pretty much see the effect when you test them and have a read out of the intake temp. I believe someone just did this and the difference was 20 degrees cooler ( with the name brand ) </TD></TR></TABLE>
Link??
i rock an ebay IC and will continue to do so expletive it they work fine!
Old Jul 24, 2007 | 05:30 AM
tony1's Avatar
Default Re: China Intercoolers (Mr Wonderfull)
Maybe that's why your pistons got fucked up?
Old Jul 24, 2007 | 05:36 AM
TiAL's Avatar
with the lighting, that bov looks like a knockoff too
Old Jul 24, 2007 | 06:27 AM
mahatma's Avatar
where can i get one of those *** nog manifolds?!?
Old Jul 24, 2007 | 07:50 AM
TheWickedOne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">
only ching chong meow part on the setup though....
Now is that necessary ???
Old Jul 24, 2007 | 07:53 AM
Default Re: China Intercoolers (akira712)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akira712 &raquo;</TD></TR><TR><TD CLASS="quote">
Link??
i rock an ebay IC and will continue to do so expletive it they work fine!</TD></TR></TABLE>
Search the forced forum of this recent topic, you will see it in there.
Old Jul 24, 2007 | 09:06 AM
c-techracing's Avatar
if i was chinese, i would have to try to beat your *** down.
Old Jul 24, 2007 | 09:08 AM
HiProfile's Avatar
If you look at the interior and exterior fins of an ebay fmic and then at a precision or garrett core, you'll notice there's like twice the fins. Meaning you need a bigger 'named' core to flow X amount of air, but you need a bigger ebay core to get the same IAT's. Most 350+ whp projects have enough money invested where another $200 will not make a dent in the price.
Old Jul 24, 2007 | 09:23 AM
raene's Avatar
Default Re: China Intercoolers (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe that's why your pistons got fucked up?</TD></TR></TABLE>
Maybe I'm using one of the eBay cores as well and I cracked the #4 sleeve... I don't think the IC is cooling enough, or maybe the IAT wasn't reading fast enough. I haven't determined the cause of it blowing, not saying the IC blew my engine at all, but it's one more "possible" cause of detonation.
Throwing my 2c in there I'm looking to replace with a high-quality core whenever I get it running with high boost again.
Old Jul 24, 2007 | 10:03 AM
lambertincorp's Avatar
Default Re: China Intercoolers (raene)
365 whp
Old Jul 24, 2007 | 10:27 AM
akira712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">510 whp at 20 psi on pump......
XSpower 31.5x12x3-3 inch in/out. HMT style back door end tank... Works great.....
What are your IAT's like?
Old Jul 24, 2007 | 11:35 AM
Kyle R's Avatar
Turbo H22 accord? That's awesome!
Old Jul 24, 2007 | 12:09 PM
Foowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I'm using one of the eBay cores as well and I cracked the #4 sleeve... I don't think the IC is cooling enough, or maybe the IAT wasn't reading fast enough. I haven't determined the cause of it blowing, not saying the IC blew my engine at all, but it's one more "possible" cause of detonation.
Throwing my 2c in there I'm looking to replace with a high-quality core whenever I get it running with high boost again. </TD></TR></TABLE>
Where is your iat sensor mounted? on the heatsoaked intake manifold? or before the throttle body?
Old Jul 24, 2007 | 12:44 PM
agrn93ls's Avatar
pack a lunch... lmao
Old Jul 24, 2007 | 01:38 PM
raene's Avatar
Default Re: China Intercoolers (Foowee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foowee &raquo;</TD></TR><TR><TD CLASS="quote">
Where is your iat sensor mounted? on the heatsoaked intake manifold? or before the throttle body?</TD></TR></TABLE>
Heatsoaked intake manifold. One of those things I always meant to change and never did
Old Jul 24, 2007 | 02:38 PM
Kyle R's Avatar
I could care less... pack a lunch. Im not about to get in a pissing match again... 93% is bad enough... Have a nice day princess.
Modified by Mr Wonderfull at 2:04 PM 7/24/2007</TD></TR></TABLE>
LOL.
Old Jul 24, 2007 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">Im using a password JDM IM gasket... It helps out as bit (with heat soak) buit the heat transfers directly through the studs anyways... plus ambient, there is only so much you can do...... had to put in longer studs though... aftermarket manifold.</TD></TR></TABLE>
Have you actually done testing with an iat ?
Old Jul 29, 2007 | 01:10 PM
b16a4's Avatar
ching chong update!
Old Jul 29, 2007 | 02:05 PM
GetawayInMoscow's Avatar
crackie chan
Old Jul 29, 2007 | 02:13 PM
ScorpioMk's Avatar
I gave my ebay core to a buddy couple months ago to help him finish his setup, he put down 550whp. gsr with a 4088, 16ish psi.
Marcus
7rrivera7
11
Apr 18, 2008 03:28 PM
PreStaged12s
Jun 2, 2005 08:35 AM
accord2fast
Nov 17, 2004 10:31 AM
endlesswinterco
15
Dec 18, 2003 07:39 PM
BolivianDc2
Dec 16, 2003 01:24 PM
