Wipers working backwards, hitting wiper cowl instead of going up
Old Jul 23, 2007 | 03:25 PM
NOFX's Avatar
H-T White Ops
Default Wipers working backwards, hitting wiper cowl instead of going up
So I have a '98 Civic EX and it had the luck of being one of the 1998s covered by the wiper TSB.
So today I got a new wiper motor in and Eran and I installed it. Everything went smoothly save for a stuck clip. We put it all back together, taking care to place the linkage in the same location as it was originally.
So we tried the wipers on the lowest setting. They made a clunk sound.
The wipers are trying to cycle the wrong way. Somehow they're trying to go counterclockwise instead of clockwise.
I live in Washington and driving with RainX and no wipers is proving to be a hazard. Please help if you can.
Wiper TSB (Covers 1998 Civics only)
http://www.tegger.com/hondafaq...e.pdf
The only other thread with any information, but the OP never said how it was fixed, if it was.
https://honda-tech.com/zerothread?id=1669143
Modified by NOFX at 4:39 PM 7/23/2007
Old Jul 23, 2007 | 03:35 PM
Relic1's Avatar
one of two things, something went wrong with the install. (mechanically or electrically)
or you simply need to adjust the wiper arm position.
Old Jul 23, 2007 | 03:40 PM
Eran's Avatar
HT White Ops
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">one of two things, something went wrong with the install. (mechanically or electrically)
or you simply need to adjust the wiper arm position.</TD></TR></TABLE>
They're rotating backwards, wiper arms or not. It has nothing to do with that. And there's nothing electrically wrong, it's a 5-pin plug that can only be plugged in one way.
I'm pretty sure I know what the problem is, and it's the position of a small arm that attaches the linkage and the motor. Now the problem is yanking all that **** back apart, and fixing it.
Old Jul 23, 2007 | 05:17 PM
Eran's Avatar
HT White Ops
And it's fixed. I just had to toy with the connecting arm and do some test ON/OFF until it was parked in the right position.
Old Jul 23, 2007 | 05:30 PM
NOFX's Avatar
H-T White Ops
Though I don't believe the TSB mentions it, anyone who needs to swap out the motor or remove the linkage or whatever, might want to use a Sharpie to mark so the spindle matches up.
jdm2u
Mar 2, 2009 08:42 PM
mugencx
10
Oct 26, 2008 07:54 PM
slvrcivic97
Jul 27, 2003 08:57 PM
x00gsr
Jul 2, 2003 05:52 PM
