My Honda keeps dieing
alrite so i have a 1999 Honda Civic LX
and it keeps on dying when it
-rains
-snows
-or really cold days
-or REALLY hot days
its like it has a seizure or sumthin and
then it gets to a point when it jsut shuts
off on its own. nad its bugging me cuz its
happened to me while i was on the highway
a few times now
i was just wonderin is it suppose to do
that or am i gonna have to get it check
out
Modified by KrazieKongLo at 3:50 PM 7/23/2007
-rains
-snows
-or REALLY hot days
a few times now
out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrazieKongLo »</TD></TR><TR><TD CLASS="quote">please i need some serious help before winter comes around again</TD></TR></TABLE>
it could be a couple of things. be more specific.
is there any check engine lights on?
how many miles does the car have?
i have about 66000 miles on it and yes the check engine does flash on and off for a bit sometimes it stays on steady then after some time the check engine light turns off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrazieKongLo »</TD></TR><TR><TD CLASS="quote">i have about 66000 miles on it and yes the check engine does flash on and off for a bit sometimes it stays on steady then after some time the check engine light turns off</TD></TR></TABLE>
ok, you want the CEL to stay on steady. if you can get it to stay on, follow the directions on this link. it will help pin point your problem.
https://honda-tech.com/zerothread/1901557
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
thanks for helping
thanks for helping
thanks for helping</TD></TR></TABLE>
The MIL does turn off when you solve a problem, or if it is intermittent, but it will store a code in the ECU regardless, and it will stay there until you drive around at full warm 40 times without the same problem, unless you disconnect the battery.
If the check engine light is "FLASHING" this means that there is possible catalyst damage and the vehicle is misfiring, not getting enough air, or getting to much fuel. any one of these things would cause a rich condition cause the mil to flash and possible cause the car to die due to wrong Air fuel ratio. but you need to get it checked out by a profresional if you are not some what automotive inclined cause the longer you wait the more $$$$$$$$$$$ its going to cost you!
CiViC05cHiCk
11
Mar 27, 2005 12:16 PM
