rotors and brake pads
hey guys , im going to change my rotors and pads .. all 4 .. wondering whats a good set up, i saw went to a local shop and they said around 200 for original parts ..
there are alot of people on here that will tell you to get autozone rotors and a sick set of pads. I don't know what your car is used for, show/race, but i would not cheep out on the brakes. If you are making crazy HP, i would upgrade to a big brake kit, like 2K$. I'm not, my motor is still stock and i wanted to take my car on the track and have good luck. I got brembo sloted OEM repacement rotors and Hawk HPS pads and SS lines with motul 600 brake fluid. It worked out great, only problem is that i have white rims and there is crazy brake dust. Next season i may get a more agressive pad for the front to help the car rotate a littel more during auto-x's. Hope this helps.
yea, i heard brembo are good, i just use the integra for a daily car .. everything is pretty much stock except for some rims and minor bolt-ons .. how much should a set up like that cost ?? and for installations ..
with basic hand tools and some research you could prolly do your own brakes. If it's just a daily then you could do OEM replacements.
I've heard good things about AXXIS Metal Master pads. If you want you could do some stainless steel lines. Brembo blank rotors. Do a good brake bleed with some new fluid. Should really be all you'd need for daily driving duty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC »</TD></TR><TR><TD CLASS="quote">if you don't really plan on tracking or auto crossing the car, just stick with OEM. If you want a small upgrade, get the brembo blank rotors.</TD></TR></TABLE>
I would have to agree, but instead of upgrading the rotors i would just upgrade the pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrinno »</TD></TR><TR><TD CLASS="quote">OH, I see, so where is a good place to get both OEM rotors and brake pads ? and are the brake pads paintable? </TD></TR></TABLE>
you want to paint the brake pads or the calipers? the pads i dont see the point because they arent too noticable and especially dont paint the area where it comes into contact with the rotor.
i think its the calipers that you want to paint. And probably not that much between brembo blanks and oem. I think the brembos are probably built to a little higher standard, but nothing really noticeable. I got my brake pads at http://www.tirerack.com and that is where you will notice a difference. Stainless Steel lines are also a cheep mod you can do to make your peadle a little stiffer, and repalce the fluid like someone said in here. But again, if it's just a daily driver, why mess with anything. Just stay OEM!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">How would brembo blanks differ from oem blank rotors in terms of performance? or would there even be a difference?</TD></TR></TABLE>
It would probably have to do something with the material that they are made out of. I'm guessing, and this is just a guess, that the brembos could handle heat a little better.
I just bought a new set of brembo sport slot rotors. I still have the stock pads. I found that the brembos just seem like they just work better, even with the stock pads. I am sure that they would be a lot better with some hawk pads but I do not need new pads.
I think you would like the brembos. Here is where I bought mine. They weren't too expensive.
http://www.thepartsbin.com
Modified by RGK500 at 8:00 PM 7/23/2007
