lsv dowel pin question
ive been taking my sweet time on finishing up my build on this lsv setup. so yesterday i had some time to work on the motor and tried to fit the dowel pins on the block to the head. i have GE dowel pins btw, and i found that it fits to the ls block perfectly, but when i fit it to the b16a head, the holes ON THE HEAD are a little small. o yea and the dowel pins are fitted on the intake side since there was no fitting for the exhaust side to match on the head to the block. what did u guys use to make the hole bigger? i dont have a drill press so if i did the work myself at home, it wouldnt be accurate. is there any other way to do this? or should i just bring it back to the machine shop and have them handle it for me? i just want to finish this up now that im getting more anxious. thanks for any help in advance
Modified by bnut510 at 5:13 PM 7/23/2007
bump for some help. i thought the GE dowels would fit with no mods needed except to the gasket. looked at the GEvtec conversion instructions from somewhere here on the search thread but it says that it should fit. im confusedddd outta my mind
I alo used them on the intake side, Just torqued them down with the headstuds and they went in w/o a problem...
Did you make sure the holes were free of obstruction
so do u mean that it wont fit by just pushing them in? they need a little force? its free from any obstruction though i checked. the block and head was all done up by a machine shop so everything is freshly surfaced and lookin good. bump for some more help??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrayzor »</TD></TR><TR><TD CLASS="quote">aren't the dowel pins different sizes on each side? </TD></TR></TABLE>
yes they are. bump for help
Are you installing them in the correct location? They dont go in the open holes in the block. They are supposed to go over the head studs on the exhaust side. Look at the holes where the head studs go in the block on the exhaust side and you will see what I'm talking about.
Also wouldn't hurt if you read the directions that came with the G.E. LS-V kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol »</TD></TR><TR><TD CLASS="quote">Are you installing them in the correct location? They dont go in the open holes in the block. They are supposed to go over the head studs on the exhaust side. Look at the holes where the head studs go in the block on the exhaust side and you will see what I'm talking about.
i read the ge install kit today actually hahaha and im at work right now so im not 100% sure till i go home and look at where exactly im placing the dowels. LOL thanks for the genius advice, im gonna check, take some pics, and repost. thanks for the help tho
</TD></TR></TABLE>i read the ge install kit today actually hahaha and im at work right now so im not 100% sure till i go home and look at where exactly im placing the dowels. LOL thanks for the genius advice, im gonna check, take some pics, and repost. thanks for the help tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol »</TD></TR><TR><TD CLASS="quote">Heres a pic to help out from when I did my LS-V:
thanks man, that pic really helped alot. i didnt get a chance to take some pics yesterday but i will when i get a chance to. so everything is ok now, i was in the wrong hole like u guys said. with that done, i was reading up on the oem ls gasket that i should use a 14mm bit to drill out the gasket for the dowel pin to fit? sorry im a noob at building a lsv
</TD></TR></TABLE>thanks man, that pic really helped alot. i didnt get a chance to take some pics yesterday but i will when i get a chance to. so everything is ok now, i was in the wrong hole like u guys said. with that done, i was reading up on the oem ls gasket that i should use a 14mm bit to drill out the gasket for the dowel pin to fit? sorry im a noob at building a lsv
im not using a GE hg tho? im using a oem ls hg. it was late last night when i was playing around with the motor, and it seemed like the dowels wouldnt fit over the hg but ill check it again tonight and see what happens. so the only reason y people are drilling the stock hg is because they are using stock dowel pins?
i had to sand/grind down my GE dowels a lil on my LS/Vtec setup. they fit a lil too tight outta the box. has help up fine over 2 years, well till i blew the poo outta the #1 rod bearing anyway.
b20vdelsol619
12
Sep 21, 2009 11:47 PM
