Code 13(barometric sensor) How do i troubleshoot this?
Old Jul 23, 2007 | 08:18 AM
irishgreen4's Avatar
Default Code 13(barometric sensor) How do i troubleshoot this?
I have an engine light on for a baro sensor but i have no idea on how to troublshoot it. I have access to alldata but the only information it gives me is that the baro sensor is integrated into the ecu and cannot be serviced. So thinking that it cant be serviced i replaced th ecu and found i have the exact same problem but no way to figure out what is causing it. If anyone knows anything i can do or what else could cause this light to ogo on i would greatly appreciate it.
Old Jul 23, 2007 | 10:07 AM
EE_Chris's Avatar
Default Re: Code 13(barometric sensor) How do i troubleshoot this? (irishgreen4)
Turbo'd? Using a VAFC?
Old Jul 23, 2007 | 10:44 AM
EX-T's Avatar
Default Re: Code 13(barometric sensor) How do i troubleshoot this? (EE_Chris)
Check voltages across your MAP (Manifold Absolute Pressure) sensor.
Old Jul 23, 2007 | 02:27 PM
Default Re: Code 13(barometric sensor) How do i troubleshoot this? (EX-T)
The engine is completely stock.
Old Jul 23, 2007 | 02:49 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">Check voltages across your MAP (Manifold Absolute Pressure) sensor.</TD></TR></TABLE>
Old Aug 29, 2012 | 04:05 PM
BAD9AZZ1MOFO5's Avatar
Im having the same problem...did u ever fix it......????? Very interested
Old Aug 29, 2012 | 05:27 PM
beecee18's Avatar
Depending on year make and model alot of applications have the baro sensor integrated into the ECU.
Start with factory service manual for your application and follow the troubleshooting flowcharts in correct order for code 13
Old Aug 29, 2012 | 06:00 PM
Former User's Avatar
Old thread closed.
roy ezechukwu
Feb 6, 2014 02:13 PM
viking-101
19
Apr 14, 2012 04:38 PM
sh!ft
May 13, 2009 01:18 PM
jdmkid_82
Oct 29, 2008 05:51 PM
EVIL_AWD
Oct 9, 2003 08:18 PM
