ecu code
Old Oct 29, 2008 | 03:22 PM
jdmkid_82's Avatar
Default ecu code
alright, when i turn the key on my d16z6 the check engine blinks 3xs then a pause.. and one long blink.. and it just repeats it.. any idea what code that is?
Old Oct 29, 2008 | 03:46 PM
z6hatchboy's Avatar
Take a look in the sticky, long blinks are 10'a and short are 1's. So 2 longs and 3 shorts would be 21. If its just something like 6 shorts than its a 06 also 6.
Old Oct 29, 2008 | 03:53 PM
jdmkid_82's Avatar
Default Re: (z6hatchboy)
well its 3 shorts then 1 long one then it repeats
Old Oct 29, 2008 | 03:58 PM
z6hatchboy's Avatar
maybe its a 3 and a 10 then. if the pause is between the 3 and the long 1
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
Old Oct 29, 2008 | 04:24 PM
jdmkid_82's Avatar
so 13? whic<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">maybe its a 3 and a 10 then. if the pause is between the 3 and the long 1
13 BARO - atmospheric pressure sensor </TD></TR></TABLE>
what is the BARO then?
Old Oct 29, 2008 | 04:59 PM
z6hatchboy's Avatar
13 is the barometer. Its in the ecu, if its bad youll need another ecu because that part isnt sold seperately and is soldered in the ecu
The only things though is: it blinks the code in order. So if you indeed get a 3 then 1 then it cant be 13. A 31 is some related to the auto tranny.
Old Oct 29, 2008 | 05:33 PM
jdmkid_82's Avatar
auto tranny? thats odd then cuz have 5speed manny? from the z6
Old Oct 29, 2008 | 05:51 PM
mikehawk's Avatar
Default Re: (jdmkid_82)
if it were 13 it would be BLINK (long) then 3 shorts ..
it could even be two seperate codes .. 3 and 10 i guess .. depending on how long the pause is ..
3 blinks then a long pause and a long blink. idk tho for sure.
efyou999
May 24, 2012 12:21 AM
sh!ft
May 13, 2009 01:18 PM
97civic123
Jul 13, 2007 04:14 PM
invisible
34
Mar 16, 2007 07:19 PM
cottagecreep
Jan 28, 2003 03:18 PM
