Half-core radiators, pictures and how do you guys mount half cores in a DC chassis?
Old Jul 23, 2007 | 07:34 AM
rebo0t's Avatar
Default Half-core radiators, pictures and how do you guys mount half cores in a DC chassis?
I bought a brand new fluidyne full core radiator and found out today that the header I'm ordering would require a half core radiator. I want to know how you guys mount this in your DC chassis the RIGHT/Correct/NON GHETTO way. When I was turbo in my DC2 I fabbed and welded up some aluminum brackets but it still didnt look the way I want it to. I want a clean look, so show me what you guys do and what are my options?
BTW, does the Delso SI radiator mount up to the stock location?
Old Jul 23, 2007 | 07:15 PM
rebo0t's Avatar
Old Jul 24, 2007 | 12:33 AM
nate_2k5's Avatar
Default Re: (rebo0t)
you just use the passenger side radiator stay
Old Jul 24, 2007 | 01:08 AM
rebo0t's Avatar
What about the bottom foot?
Old Jul 24, 2007 | 08:32 AM
nate_2k5's Avatar
fits into the same place the passenger side foot does on a full size radiator
Old Jul 24, 2007 | 09:45 AM
rebo0t's Avatar
Yeah but there are two feets. What I did when I used to have a half core is I cut about 1" of aluminum rod and welded it to the bottom of the radiator so I could fit fit a second foot. But what I am asking is besides cutting and fabbing, is there another way of installing a half core into a DC?
Old Jul 24, 2007 | 10:06 AM
VTEC_PRODUCTION's Avatar
if you want the best fit you need to cut and reweld...but there is always zip ties and duct tape
Old Jul 24, 2007 | 01:23 PM
rebo0t's Avatar
Wasn't there a half core radiator that was direct fit? I thought it was the del so?
Old Jul 24, 2007 | 02:20 PM
Kyle R's Avatar
I didn't know there was one that's a direct fit. What was described above is the popular method.
Old Jul 24, 2007 | 02:58 PM
rebo0t's Avatar
Ah thanks, I guess I'll just have to fab up something again. Its not a problem
Old Jul 24, 2007 | 03:16 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t &raquo;</TD></TR><TR><TD CLASS="quote">Ah thanks, I guess I'll just have to fab up something again. Its not a problem</TD></TR></TABLE>
just having it sit in the passenger "foot" will be fine. Then I flattened out one of the top rad brackets and used a 8mm bolt and nut in oem hole on the upper rad support.
Old Jul 24, 2007 | 03:20 PM
Kyle R's Avatar
Default Re: (skunked)
That's how I plan to setup mine. H2b sweet
Old Jul 24, 2007 | 03:53 PM
EARLdaSQUIRREL's Avatar
official honda whore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
i had mine like that and it just felt cheesy
just take the driver mount off (drill out spot welds) and weld it in the correct location that a half-core radiator is needed while using the passenger mount
Old Jul 24, 2007 | 05:06 PM
rebo0t's Avatar
Yeah my setup before I made new aluminum brackets but it looked aftermarket. I wanted to know if there was another solution so it looks OEM. But I'll figure something out
Old Jul 24, 2007 | 05:16 PM
use the oem brackets but just reposition them, everything is fairly simple with the use of a spot weld drill bit and a mig welder
Old Jul 24, 2007 | 06:36 PM
black98gsr-t's Avatar
Default Re: Half-core radiators, pictures and how do you guys mount half cores in a DC chassis? (rebo0t)
i used this as a guide when doing mine:
http://www.full-race.com/artic...l.pdf
Old Jul 25, 2007 | 09:12 AM
rebo0t's Avatar
Thats exactly what I did before. But I still had to bend my radiator stay.
Old Jul 25, 2007 | 09:30 AM
gsrious's Avatar
there is another solution to mounting up the half style radiator to a dc chassis.
home depot sells long rods of steel/aluminum. buy the flat ones(but thick enough to supports the weight of the radiator w/ coolant, and also the bumps vibratioons from driving). you'll want it just lng enough to go from tab to tab of the bottom mounts. while you have that flat strip(more like bar) of steel going across, use a good size bolt to act as the original feet of the stock radiator. reuse the rubber bushing on the bolts(feet) so it sits snug.
you then hav a whole new bar(the one you just put in) to drill out where ever you want to position the radiator.
____________________________________________
^^i know that the info i gave you is very vague. there will be minor fabing involved. thats only a start to set you started.
oh, btw... this way if you ever want to change back to the full size rad. you still have the original mounts in their original location.
enjoy
93dagsr's Avatar
just asking do the half core radiators cool just as good as the stock ones?? what other mods do u have to do to make it work? or is just a basic drop in type of deal?? and what if u have a/c?? any mods req'd there??
Old Jul 25, 2007 | 09:33 AM
skunked's Avatar
Default Re: (93dagsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dagsr &raquo;</TD></TR><TR><TD CLASS="quote">just asking do the half core radiators cool just as good as the stock ones?? what other mods do u have to do to make it work? or is just a basic drop in type of deal?? and what if u have a/c?? any mods req'd there??</TD></TR></TABLE>
If you have AC it's not worth it.
Most are doing this for turbo clearance and weight reasons.
Old Jul 25, 2007 | 09:34 AM
93dagsr's Avatar
o i c thank you!
CasperX
Dec 18, 2007 02:34 PM
PrecisionH23a
Honda Motorcycles
Apr 19, 2006 11:38 PM
r0c5t4r
Jul 1, 2004 09:18 AM
